Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Do I need a bump map when I have a displacement or height map?
1 REPLY 1
carlcox62
517 Views, 1 Reply
Just for theoretically understanding. When I have displacement or height map it is its unneccessary to have a bump or normal map??
1 REPLY 1
damaggio
in reply to: carlcox62
A height map is a displacement map.
It can also be used as bump map, or you can also combine  a normal map over the displacement to add more detail.
If you get all the detail you need from a displacement map then there's no need do add anything else.
