Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Distortion in depth maps???
3 REPLIES 3
395 Views, 3 Replies
Hi Guys,
I'm working on some computer vision stuff, and I thought making some simple synthetic data in maya would be really convenient especially because I need a normal pass and depth pass. Anyways, Ive rendered out my beauty pass with mental ray and also a depth pass. I then used the camera characteristics to create 3D points at each pixel and then applying the depth to turn it into a point cloud. The results are pretty nifty but i noticed that my ground plane is not flat!snapshot02.png
The included image are my results. I know this might be a bit out of scope for a Maya users board but I was wondering if maya/mentalray adds distortion to output images/depth maps by default. (I'm confident I didn't do it!)
I've attached the relevant passes.
3 REPLIES 3
kollig
May be some gamma issue. Have you checked (or taken into account) that the passes are not linear data anymore but written out with gamma correction?
mspeer
in reply to: kollig
Hi!
How is your depth pass rendered, has it a min and max setting?
kollig
One further possibility: Mismatch between depth (distance to plane perpendicular to optical axis) and distance (to eye point)?
Technology Administrators
