Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Displacement/Mesh History Issues
7 REPLIES 7
Message 1 of 8
TheBlack95
1110 Views, 7 Replies
TheBlack95
Hi
So I'm texturing some brick walls using PBR materials from Quixel Mixer. When using this shader on a new plane(or any new mesh with history), it appears fine. However, when I apply the same shader network to a wall that I've modified (seen on the screenshot, left side) it just appears flat.
I learned online and while at university to clear the mesh history once finished modifying to help keep the scene tidy?
just keep the mesh history to allow the PBR to show the displacement maps?
Josh
Hi
Josh
Labels (1)
7 REPLIES 7
Message 2 of 8
mspeer
in reply to: TheBlack95
mspeer
Hi!
Very likely the objects have different scale values, this also affects the scale of the displacement.
Just correct this.
For further help, please provide a scene-file.
Hi!
Just correct this.
Message 3 of 8
TheBlack95
in reply to: mspeer
TheBlack95
Hi, thanks for your reply.
I just can't see it being a scale issue as the file nodes are all connected to one singular 'place2dTexture' node.
Here is the file with just the 2 walls in question. I've removed everything else to compress the size (hasn't changed the outcome of this problem. The textures are from Quixel Bridge, the one I used was called 'Rough Brick Wall'. I can only provide them from another link as the forums only lets me upload 3 files at a time.
Josh
Josh
Message 4 of 8
TheBlack95
TheBlack95
Here are the textures I used from Quixel
https://quixel.com/megascans/home?search=brick&assetId=vh2pddg
Message 5 of 8
nobody_b
nobody_b
freeze the transformation of your plane
Message 6 of 8
TheBlack95
in reply to: nobody_b
TheBlack95
As soon as I click Freeze Transformations, it flattens the wall making the normal maps and displacement maps useless
Message 7 of 8
TheBlack95
TheBlack95
freezing does work, but I have to increase the displacement height from 2.00 up to 20 and above
Message 8 of 8
mspeer
mspeer
Hi!
As assumed it is a scaling issue.
When your displace a surface by 0.1 and scale the object up by 1000, then you get a displacement of 100.
If you create a new large surface and apply the same shader (or use freeze transformation ) then you still get only a displacement of 0.1.
As your objects are very large also using a very large large displacement value is normal, so use whatever value you need.
Hi!
