Announcements
Deleted Contribution Map still Rendering
I am working in Maya 2016 with contribution passes. I originally had a few different maps which I went in and removed from my render layer. However when I batch render the project all of the passes from the deleted maps are still rendering. I'm not sure how else to remove them as the layer is not showing any assigned maps in the channel box. Is there another place I could find the missing maps and delete them for good?
Any other ideas?
Thanks!
keyner.chavarria
Hi SunPitchers,
Can you please attach an screenshot and if you can the scene file will be great.
Thank you.
Keyner Chavarria
Autodesk Maya Specialist
Hi Keyner,
Thank you for your response. I have attached my scene file and a screenshots of what is rendering.
santd
Hello @Anonymous,
I took a look at the scene file and I am seeing some strange things occurring. Definitely seeing the contribution maps in there still when rendering. However, I am also seeing the following in the render settings:
Notice how the tabs are all messed up. I think this maybe a corruption with your scene file. Could you try selecting your scene contents and exporting them into a new scene to see if that fixes the issue. I tested a new scene and the tabs are fine in a new scene I only see this in your particular scene file.
Cheers,
David Santos
Hi Santd,
I'm not sure how that happened, but your solution seems to have worked!
Thank you very much for your help!
