Message 1 of 17
03:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Newbie learning maya (from 3ds max)
I am trying to get crytomatte passes out of Arnold.
When I look at the CM layers in the arnold renderview they look good. I then export the frame as a multi-pass exr.
I then bring them into compositing (in this case after effects using ProEXR).
After Effects also sees the layers fine, but there isn't any actual cryptomatte data to create mattes from.
In other words, so the passes look visually correct, there are no ID's (material or object or asset) to create mattes with.
I feel like I am probably missing one simple step, but that I am close!
