Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Command line render not the same quality as batch render
7 REPLIES 7
Message 1 of 8
856 Views, 7 Replies
I have a simple scene with a sphere having a mia_material_x material.
When I render it interactively in Maya, or using Batch rendering from Maya, the quality is what I expect, ie with reflections:
When I render it via the command line on Mac OS using <path_to_mayabin>/Render  -r mr -proj <project_folder> <path_to_scene>/TestRenderCmdLine.ma, I miss all the material reflection:
Any idea why ?
Thanks !
7 REPLIES 7
Message 2 of 8
i think first one is mental ray render and second is maya software render. so you for got the proper setup of render globle. thats it .
Message 3 of 8
Trying to force the renderer to MR is the same, I however found out that running the script with another user was working better. Seems to be linked to the environment. Thanks for your answer anyway.
Message 4 of 8
dunetune
I got exactly the same problem.
using the commandline (osx, maya2013/2014) reflections are not rendered.
how exactly did you solve it ??
Message 5 of 8
in reply to: dunetune
Basically rendering via the Terminal gives me this issues because, I
believe, of wrong environment settings (even if I never could find the
right ones).
Rendering from a Cocoa App for example using NSTask makes it working fine.
I can provide the sample code if needed.
Message 6 of 8
dunetune
I have to bring that issue up once more because I still haven't solved the problem.
even the autodesk support couldn't help me.
using another user account worked once and then it didn't work anymore …
after wasting a lot of time with this bs I bit the bullet and formatted my HD, made a clean install of 10.8.5 and reinstalled maya2014.
… and you know what? – nothing has changed. it's still the same behavior.
right ones).
what do you mean with "environment settings"? the maya environment settings or the OSX system preferences?
Message 7 of 8
Not sure if you are a developper, but I wrote a little Cocoa application that's starting a render (using NSTask), and the result is then perfect.
Message 8 of 8
dunetune
hey earthHobbit,
good news:
the problem is solved!!
the incorrect results given by commandline rendering are based on the language and region settings of OSX and a resultant confusion of DOT and COMMA …
it's a maya bug.
but after setting the system LANGUAGE to ENGLISH and the REGION to UNITED STATES everything works as it should 🙂
I don't know how many days and nights I've been struggling with this …
