Greetings All,
I am setting up my color rules in Maya 2022. I am using a substance to Maya workflow so my file names are pretty consistent. The new rules I made for the LDRI images work fine. For example, any file with "*BaseColor" is set to sRGB and any file with "*Normal" is set to raw etc etc.
However, I cannot seem to get the .exr and hdr rules to obey setting the color space to "scene-linear Rec.709-sRGB" instead of "raw" which is the default.
Here is what I have tried
- editing the rules in Maya with the default config file and saving the preference XML. Exrs and hdrs still come in as raw.
- Duplicating the Maya config folder and editing the config file so that the rules set exr and hdr files to "scene-linear Rec.709-sRGB". Exrs and hdrs still come in as raw.
- I tried adding all the rules I would need directly in the new config file but then I was getting parsing errors.
I may be missing something or there may just be a bug, I am unsure. But the fact that it is ONLY the exr and hdr files that are resisting the changes makes me think it is something I am doing, or not doing.
Any help would be appreciated.
Cheers,
B
