Announcements
Character Model And Animation Not Appearing In Render
c.adams0620211
c.adams0620211
Community Visitor
Community Visitor
Hi there. I have come across this problem when trying to render my animation. My rigged and animated character model seems to disappear in the render. I thought this might've been to do with the materials but I have imported the character model that hasn't been rigged or animated and this model appears in the render as you can see in the images. Does anyone know how I can fix this without losing the animation or the rigged character? Any advice will be hugely appreciated on what to do here. Thank you!
Kahylan
Hi!
In the bottom right corner of your screenshot I can see this warning:
// Warning: resetting parameter nlist on Character_Model/Character_ModelShape (found: nans or infs) //
This usually indicates that there are problems with your mesh which stop the mesh from rendering.
Here is an old thread on how to fix it:
https://forums.autodesk.com/t5/maya-shading-lighting-and/arnold-not-rendering-one-piece-of-geo/td-p/...
Alternatively, if your animation is finished, instead of unbinding and rebinding skin and fixing your mesh, you could also try to alembiccache your animation and see if the cache geometry shows up in the render.
I hope it helps!
