Hi guys,
I am fairly new to Maya and I'm trying to learn the hard way by watching tutorials. I am currently using Autodesk Maya 2020.
However I've come quite a long way in the process of sculpting a human head and now I am doing the eyelashes. I have created a basic eyelash mesh, and Xgen finally seem to be working fine generating the Primitives (I've only had trouble with Xgen lately).
I have followed a step-by-step tutorial uploaded by Academic Phoenix Plus on how to create eyelashes, but I am currently stuck. I want a darker color to the eyelashes, but I can't figure out how to change the color of the Primitives / eyelashes. From the tutorial (timestamp 12:35 into the video) it seem she goes directly into Hypershade graph, pick "HairPhysicalShader" and from there just adjusting the slide of the Root Color, Tip Color which instantly changes the attributes of the Primitives /eyelashes.
However, when I do this, it seems that the Hair Physical Shader is applied to the mesh itself? When I adjust the slide of the Root Color, Tip Color it just changes the attributes of the mesh? No change happens to the Primitives/eyelashes? What am I missing or doing wrong? Something to do with the connections in Hypergraph?
I don't have a ton of experience working in the Hypershade graph, so please (if possible) explain to me in simplistic way.
Please se attached picture. As you probably can tell, the mesh itself has a "yellowish" tint to it.
Thank you in advance!
