Can not solve normal map problem
I created low poly model in Maya and sculpted little scrathes in Blender and bring the obj file to Maya again.
And whenever I try to bake normal map it seems so weird and I can't find solutions for me.
I tried simple models like a cylinders it also gave me same problems.
The right one is high poly and left oone is the low poly in 6 mode with normal map.
Christoph_Schaedl
Is your file texture node set to raw color space for the normalmap?
https://linktr.ee/cg_oglu
If I make it raw It seems little better but still..Is this my UV problem?
Christoph_Schaedl
How does it look like now?
And how does your uvs look like?
