Hi guys 🙂
i am using camera sequencer in maya to create a movie and create alot of shots in one click .
There is one problem :
when i playblast the movie and "render it" i can see all the cameras , light , joints icons in the playblast.
But if i am doing plablast without camera sequencer i can hide this in view options .
What i mean that the settings is not as same in playblast option via camera sequencer , and i see all the cameras , light , joints icons - even i hide them 😞
Any help?
Solved by mspeer. Go to Solution.
Hi!
"view options"
What do you mean with this:
If i disable something in Viewport menu: Show -> ...
it will not be rendered, please upload a screencast.
Hi ,
this is my show > view settings in the playblast.
When i am running "normal"" playblast via this settings all works find , and i will see only the settings i've choose in
how > view settings
But the settings is not saved when i run playblast in this options , via "camera sequencer"
Thanks for you help 🙂
Hi!
Sometimes it works but most times not, i was not able to find the pattern.
As Workaround i suggest to use Show menu directly and not the Playblast Override
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
