Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Basic Arnold standard surface shader settings for wood-like material
greech82
greech82
If you had to generate a raw wood shader without using any patterns or textures (so no grain, uniform color), just the settings of the Arnold standard shader itself, what are the diffuse and specular settings?
laomusic_arts
Hi!
Here it is my approach to this:
To create a raw wood shader using Arnold’s Standard Surface shader, adjust the following:
Diffuse Settings:
- Base Weight:1
- Base Color: Neutral brown (around RGB 0.65, 0.55, 0.45)
Specular Settings:
- Specular Weight: 0.1–0.2
- Specular Roughness: 0.5–0.7
- Specular IOR: 1.45
This will give you a flat, raw wood look without using textures or patterns.
Hope this helps others too!
LAO
