Baked colour ID map artefacts
GodToldMeToDoIt
GodToldMeToDoIt
I'm seeing some weird artefacts in the colour ID map baked in Maya for use in ArmorPaint.
If I load up the map in GIMP and ramp the brightness and contrast I see this:
Which results in this:
The outer surface was projected.  The inner rusty material was UV painted.
Any ideas?
_sebastian_f
how do you bake?
GodToldMeToDoIt
Lighting/Shading > Transfer Maps
_sebastian_f
while photoshop gives me clean masks from the bake i can reproduce what you see.
for now the only solution i can offer is to bake as exr which gives you a 32bit image and it seems to work without artifacts .
