Arnold not rendering image plane behind object w/ transmission
mikehalak007
mikehalak007
Hi all,
I'm seeing an issue with shader transmission, image planes, and rendering while using Maya 2018 + Arnold MotA 3.1.2.1.
Specifically I have an image plane placed behind a transparent object; the background image appears through the transparent object in the viewport, but does not render in Arnold.
This is clearer in the screen capture, showing the viewport at left, shader attributes in the center, and Arnold render on the right. Please note the transparent wine glasses obscuring the background at right.
I've checked:
Shader / ai standard surface settings:
- transmission weight set to '1'
Geometry object:
 - Arnold 'opaque' is unchecked
Image plane settings:
- visible in reflections
- visible in refractions
Render settings:
-Ray depth (in render settings)
The most recent info I've found at https://forums.autodesk.com/t5/maya-shading-lighting-and/arnold-5-image-plane-render-problems/td-p/7... does not seem to resolve or suggest a specific workaround...
Are people still encountering this issue–is there a solve? Many thanks:)
Stephen.Blair
The image plane (aka the background) is not visible to transmission rays. It's visible to camera rays only.
Even if it was visible to transmission rays, the image plane object is effectively infinitely far away, so there would be not actual refraction.
If you want something that's visible to transmission rays (or any other ray besides camera rays), you'll need to add an object in the scene as a backdrop.
// Stephen Blair
// Arnold Renderer Support
mikehalak007
Thanks Stephan, I'll take the 'image-object backstop' approach for a spin. Cheers
yessben59
Community Visitor
Community Visitor
I have the same problem , background does not appear behind transmission as you see in picture
however , I do not have this problem in another  project it appear correctly but I did not understand how I had done
