Arnold GPU Render not using all available GPU Memory
Message 1 of 13
Hello, I have been trying to render a scene in Arnold though the gpu drivers crash if I set the resolution to anything above 720p, I believe this is because only 39MB of memory is "free" for each of my gpu's.  I am running 2 gpu's, a NVIDIA GTX 1050 and GTX 1070 with completely up to date drivers, the GPU's have a total memory of 2048 and 8192 respectively although Arnold is showing that only 39MB of memory is "free" for each gpu (see attached screenshot).  Is there any way to increase the "free" memory so I can render scenes in higher resolution?
Things I have tried already:
- Reinstalling GPU drivers
- Deleting/Repopulating my GPU cache
Replies (12)
Message 2 of 13
Christoph_Schaedl
Could you postg a full log please.
Even there is something free it doesnt mean Arnold does need more. Or it needs much more. Free memory is no indicator why its crashing.
https://arnoldsupport.com/category/logs/
https://linktr.ee/cg_oglu
Message 3 of 13
Alright I have attached the Arnold Render Log.  I assumed that it crashed because of a memory problem because thats what the error was saying.
I am using Arnold Core 6.2.0.1, MtoA 4.2.1
Message 4 of 13
Christoph_Schaedl
Could you try to render the scene without displacement. And lower SubD settings.
Message 5 of 13
I tried rendering without displacement and lower poly but it still crashes when I try and render at 1k, 2k or 4k resolution.  Though It renders fine with displacement at 720p.   And I know my GPU's are powerful enough to render a scene like this in HD, it is a fairly simple scene and I am able to render scenes even more complex than this in other 3D software like Blender
Message 6 of 13
Christoph_Schaedl
Does it render with only one graphics card?
Message 7 of 13
Nope, it still crashes
Message 8 of 13
Christoph_Schaedl
Could you post a full info log. So we can see where the ram is used.
And a screengrab of the scene.
Message 9 of 13
A full info log for my pc's ram usage? how do I do that?
Message 10 of 13
Christoph_Schaedl
I postet above how todo a info log.
Message 11 of 13
Oh alright, this is what I got for the full log:
00:00:00 1549MB | log started Wed Jun 30 17:16:55 2021
00:00:00 1549MB | Arnold 6.2.0.1 [903992ac] windows clang-10.0.1 oiio-2.2.1 osl-1.11.6 vdb-7.1.1 clm-2.0.0.235 rlm-12.4.2 optix-6.6.0 2021/02/09 10:40:42
00:00:00 1549MB | host application: MtoA 4.2.1 d5445900 (master) Maya 2022
00:00:00 1549MB | running on vr-pc, pid=3168
00:00:00 1549MB | 1 x Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (4 cores, 8 logical) with 16229MB
00:00:00 1551MB | NVIDIA driver version 471.11 (Optix 60801)
00:00:00 1551MB | GPU 0: NVIDIA GeForce GTX 1070 @ 1784MHz (compute 6.1) with 8192MB (39MB available) (NVLink:0)
00:00:00 1551MB | GPU 1: NVIDIA GeForce GTX 1050 @ 1493MHz (compute 6.1) with 2048MB (39MB available) (NVLink:0)
00:00:00 1551MB | Windows 8.1 (version 6.3, build 9600)
00:00:00 1551MB | soft limit for open files is set at 2048
00:00:00 1551MB |
00:00:00 1552MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2022/shaders ...
00:00:00 1552MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderDiffuseColorAdapter uses Arnold 6.2.0.1
00:00:00 1552MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularWeightAdapter uses Arnold 6.2.0.1
00:00:00 1552MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularGlossAdapter uses Arnold 6.2.0.1
00:00:00 1552MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionWeightAdapter uses Arnold 6.2.0.1
00:00:00 1552MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionSpreadAdapter uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkFloatConstant uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkFloatComposite uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkFloatCondition uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkFloatCorrect uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkFloatLogic uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkFloatMask uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkFloatMath uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkColorComposite uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkColorCondition uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkColorConstant uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkColorCorrect uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkColorLogic uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkColorMask uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkColorMath uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkChannels uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkPremultiply uses Arnold 6.2.0.1
00:00:00 1552MB | lookdevkit_shaders.dll: ldkSimplexNoise uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaMultiplyDivide uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaClamp uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaGammaCorrect uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaCondition uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaReverse uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaBlendColors uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSamplerInfo1D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSamplerInfo2D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaPlusMinusAverage1D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaPlusMinusAverage2D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaPlusMinusAverage3D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaRemapValueToValue uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaRemapValueToColor uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaRemapColor uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaFile uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaPlace2DTexture uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaRamp uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaProjection uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaChecker uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaBulge uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaCloth uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaGrid uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaFractal uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaNoise uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaPlace3DTexture uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaRgbToHsv uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaHsvToRgb uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaLuminance uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaCloud uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaCloudAlpha uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSnow uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaContrast uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaLayeredTexture uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSolidFractal uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaVolumeNoise uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaBrownian uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaStucco uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaRemapHsv uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSetRange uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaImagePlane uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSurfaceShader uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaColorToFloat uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaVectorToFloat uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaPointToFloat uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaPoint2ToFloat uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaWriteColor uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAovWriteColor uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaWriteFloat uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAovWriteFloat uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaEnvSphere uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAnimFloat uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAnimPoint uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAnimVector uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAnimColor uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAnimMatrix uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaUserDataVector uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaUserDataColor uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaShadingEngine uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSamplerInfo3D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAovWriteVector uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaAovWriteVector2 uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaNormalDisplacement uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaVectorDisplacement uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaUserDataBool uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaHair uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaMeshLightMaterial uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaUserDataVec2 uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaBump2D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaFluid uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaMarble uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaMountain uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaWater uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaCrater uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaLeather uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaGranite uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaRock uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSingleShadingSwitch uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaDoubleShadingSwitch uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaTripleShadingSwitch uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaQuadShadingSwitch uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaFluidData uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaFluidTexture2D uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaSurfaceLuminance uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MtoaCameraUvMapper uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_shaders.dll: MayaFlatClosure uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyAbsFloatOverride uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyAbs2FloatsOverride uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyAbs3FloatsOverride uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyAbsIntOverride uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyRelFloatOverride uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyRel2FloatsOverride uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyRel3FloatsOverride uses Arnold 6.2.0.1
00:00:00 1552MB | renderSetup_shaders.dll: applyRelIntOverride uses Arnold 6.2.0.1
00:00:00 1552MB | xgenSpline_shaders.dll: XGenHairMapping uses Arnold 6.2.0.1
00:00:00 1552MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2022/procedurals ...
00:00:00 1552MB | mtoa_ParticleInstancer_proc.dll: particleInstancer uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_ParticleVolume_proc.dll: volume_particle uses Arnold 6.2.0.1
00:00:00 1552MB | mtoa_ParticleVolume_proc.dll: implicit_particle uses Arnold 6.2.0.1
00:00:00 1552MB | xgenSpline_procedural.dll: xgenProcedural uses Arnold 6.2.0.1
00:00:00 1552MB | xgen_procedural.dll: xgen_procedural uses Arnold 6.2.0.1
00:00:00 1552MB | loaded 121 plugins from 9 lib(s) in 0:00.02
00:00:00 1552MB | loading plugins from C:\Program Files\Autodesk\Arnold\maya2022\bin\..\plugins ...
00:00:00 1552MB | alembic_proc.dll: alembic uses Arnold 6.2.0.1
00:00:00 1553MB | cryptomatte.dll: cryptomatte uses Arnold 6.2.0.1
00:00:00 1553MB | cryptomatte.dll: cryptomatte_filter uses Arnold 6.2.0.1
00:00:00 1553MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 6.2.0.1
00:00:00 1553MB | synColor_shaders.dll: color_manager_syncolor uses Arnold 6.2.0.1
00:00:00 1572MB | usd_proc.dll: usd uses Arnold 6.2.0.1
00:00:00 1572MB | loaded 6 plugins from 4 lib(s) in 0:00.09
00:00:00 1572MB | loading plugin: C:/Program Files/Autodesk/Bifrost/Maya2022/2.2.1.0/bifrost/arnold-6.2.0.0/arnold_bifrost.dll ...
00:00:00 1572MB | arnold_bifrost.dll: bifrost_graph uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_object uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_multires_volume uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_multires_implicit uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_volume uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_points uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_implicit uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_polymesh uses Arnold 6.2.0.0
00:00:00 1572MB | arnold_bifrost.dll: bifrost_blocks uses Arnold 6.2.0.0
00:00:00 1572MB | loaded 9 plugins from 1 lib(s) in 0:00.01
00:00:00 1573MB | [mtoa] RGBA attribute file1.defaultColor has no alpha component: exporting as RGBA
00:00:00 1573MB | [mtoa] RGBA attribute file2.defaultColor has no alpha component: exporting as RGBA
00:00:00 1576MB | [color_manager_ocio] using config file D:/Program Files/Autodesk/Maya2022/resources/OCIO-configs/Maya2022-default/config.ocio
00:00:00 1610MB |
00:00:00 1579MB | [AiMakeTx] maketx: no update required for "D:/Maya Projects/Practice/sourceimages/Dougnut Texture.tx"
00:00:00 1579MB | [AiMakeTx] maketx: no update required for "D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.tx"
00:00:00 1619MB | [gpu] setting OptiX disk cache location to: C:\Users\Connor\AppData\Local/NVIDIA/OptixCache/arnold
00:00:00 1773MB | GPU 0: NVIDIA GeForce GTX 1070 enabled
00:00:00 1773MB | GPU 1: NVIDIA GeForce GTX 1050 enabled
00:00:00 1773MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:00 1774MB | [color_manager] rendering color space is "ACEScg"
00:00:00 1800MB |
00:00:00 1800MB | there are 3 lights and 145 objects:
00:00:00 1800MB | 2 persp_camera
00:00:00 1800MB | 3 ortho_camera
00:00:00 1800MB | 3 quad_light
00:00:00 1800MB | 2 image
00:00:00 1800MB | 1 utility
00:00:00 1800MB | 9 standard_surface
00:00:00 1800MB | 1 color_correct
00:00:00 1800MB | 1 range
00:00:00 1800MB | 1 driver_exr
00:00:00 1800MB | 2 gaussian_filter
00:00:00 1800MB | 1 closest_filter
00:00:00 1800MB | 144 polymesh
00:00:00 1800MB | 1 list_aggregate
00:00:00 1800MB | 1 color_manager_ocio
00:00:00 1800MB | 1 renderview_display
00:00:00 1800MB | 1 driver_arv
00:00:00 1800MB |
00:00:00 1800MB | rendering image at 2048 x 2048, -3 AA samples
00:00:00 1800MB | AA samples max 0
00:00:00 1800MB | AA adaptive threshold 0.015
00:00:00 1800MB | AA sample clamp <disabled>
00:00:00 1800MB | diffuse samples 2 / depth 3
00:00:00 1800MB | specular samples 2 / depth 2
00:00:00 1800MB | transmission samples 2 / depth 9
00:00:00 1800MB | volume indirect <disabled by depth>
00:00:00 1800MB | total depth 10
00:00:00 1800MB | bssrdf samples 2
00:00:00 1800MB | transparency depth 11
00:00:00 1800MB | initializing 175 nodes ...
00:00:00 1802MB | creating root object list ...
00:00:00 1802MB | node initialization done in 0:00.00 (multithreaded)
00:00:00 1802MB | updating 176 nodes ...
00:00:00 1805MB | /KeyLight/KeyLightShape: quad_light using 5 samples, 2 volume samples
00:00:00 1805MB | /FillLight/FillLightShape: quad_light using 5 samples, 2 volume samples
00:00:00 1805MB | /HairLight/HairLightShape: quad_light using 5 samples, 2 volume samples
00:00:00 1816MB | scene bounds: (-89.5046997 -0.226797104 -159.059036) -> (89.5046997 118.745636 159.059357)
00:00:00 1816MB | node update done in 0:00.03 (multithreaded)
00:00:00 1816MB | [gpu] preparing 176 nodes ...
00:00:00 1817MB WARNING | [disp] /Donut/Dough/DoughShape: padding is at least 10x smaller than it should be! given disp_padding: 0, recommended: 0.0587291718
00:00:00 1834MB | [gpu] updating 176 nodes ...
00:00:01 1864MB | [aov] parsing 2 output statements ...
00:00:01 1864MB | [aov] registered driver: "arv_display" (driver_arv)
00:00:01 1864MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:01 1864MB | [aov] * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:01 1864MB | [aov] done preparing 4 AOVs for 2 outputs to 1 driver (0 deep AOVs)
00:00:01 1976MB | starting render ...
00:00:01 1996MB | [gpu] building scene and compiling shaders ...
00:00:02 2236MB | [gpu] building scene and compiling shaders done in 0:00.682
00:00:03 3291MB | render done in 0:02.091
00:00:03 3291MB |
00:00:03 3291MB | -----------------------------------------------------------------------------------
00:00:03 3291MB | scene creation time 0:00.29 machine utilization (11.50%)
00:00:03 3291MB | plugin loading 0:00.12
00:00:03 3291MB | unaccounted 0:00.16
00:00:03 3291MB | frame time 0:03.31 machine utilization (18.43%)
00:00:03 3291MB | node init 0:00.03
00:00:03 3291MB | displacement 0:00.01
00:00:03 3291MB | gpu prepare 0:00.18
00:00:03 3291MB | gpu update 0:00.52
00:00:03 3291MB | gpu jit compile / BVH 0:00.68
00:00:03 3291MB | rendering 0:01.40
00:00:03 3291MB | output driver 0:00.01
00:00:03 3291MB | pixel rendering 0:01.39
00:00:03 3291MB | unaccounted 0:00.46
00:00:03 3291MB | top session self-times by category
00:00:03 3291MB | worker waiting 0:02.61 (76.95%)
00:00:03 3291MB | accumulateBucketSamples 0:00.18 ( 5.40%)
00:00:03 3291MB | GPU iteration 0:00.17 ( 5.18%)
00:00:03 3291MB | OptiX initialization 0:00.09 ( 2.87%)
00:00:03 3291MB | create_optix_context 0:00.05 ( 1.53%)
00:00:03 3291MB | updateAllNodesGPU 0:00.04 ( 1.46%)
00:00:03 3291MB | top session self-times by node
00:00:03 3291MB | peak CPU memory used 3291.52MB
00:00:03 3291MB | at startup 1551.93MB
00:00:03 3291MB | plugins 20.49MB
00:00:03 3291MB | AOV samples 5.71MB
00:00:03 3291MB | output buffers 0.77MB
00:00:03 3291MB | framebuffers 112.00MB
00:00:03 3291MB | node overhead 0.12MB
00:00:03 3291MB | message passing 0.01MB
00:00:03 3291MB | memory pools 12.05MB
00:00:03 3291MB | geometry 0.95MB
00:00:03 3291MB | polymesh 0.95MB
00:00:03 3291MB | strings 24.25MB
00:00:03 3291MB | texture cache 2.30MB
00:00:03 3291MB | profiler 0.02MB
00:00:03 3291MB | unaccounted 1560.95MB (note: interactive session)
00:00:03 3291MB | output buffers 160.00MB
00:00:03 3291MB | geometry 3.13MB
00:00:03 3291MB | polymesh 3.13MB
00:00:03 3291MB | texture cache 1.12MB
00:00:03 3291MB | unaccounted -164.25MB
00:00:03 3291MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
00:00:03 3291MB | camera 68346 ( 0.00, 1.00) ( 1.64%) ( 0.98) ( 1)
00:00:03 3291MB | shadow 4000871 ( 0.21, 58.54) ( 96.24%) ( 0.22) ( 1)
00:00:03 3291MB | diffuse_reflect 84857 ( 0.00, 1.24) ( 2.04%) ( 0.28) ( 1)
00:00:03 3291MB | specular_reflect 3026 ( 0.00, 0.04) ( 0.07%) ( 0.47) ( 1)
00:00:03 3291MB | total 4157100 ( 0.22, 60.82) (100.00%) ( 0.24) ( 1)
00:00:03 3291MB | by ray depth: 0 1 2 3 4 5
00:00:03 3291MB | total 96.4% 2.7% 0.7% 0.2% 0.0% 0.0%
00:00:03 3291MB | meshes 1
00:00:03 3291MB | shader calls 9080
00:00:03 3291MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:03 3291MB | lists 1 (100.0%) ( 0) ( 0.00, 0.00)
00:00:03 3291MB | polymeshes 144 (100.0%) ( 0) ( 1.10, 0.95)
00:00:03 3291MB | geometric elements ( min) ( avg.) ( max)
00:00:03 3291MB | polygons 20135 ( 30) ( 139.8) ( 8840)
00:00:03 3291MB | triangle tessellation ( min) ( avg.) ( max) (/ element) (% total)
00:00:03 3291MB | polymeshes 38602 ( 48) ( 268.1) ( 17680) ( 1.92) (100.00%)
00:00:03 3291MB | unique triangles 38602
00:00:03 3291MB | CPU memory use 0.95MB
00:00:03 3291MB | vertices 0.23MB
00:00:03 3291MB | vertex indices 0.11MB
00:00:03 3291MB | polygon base offsets 0.00MB
00:00:03 3291MB | polygon IDs 0.00MB
00:00:03 3291MB | triangulation 0.00MB
00:00:03 3291MB | packed normals 0.08MB
00:00:03 3291MB | normal indices 0.11MB
00:00:03 3291MB | uv coords 0.09MB
00:00:03 3291MB | uv coords idxs 0.12MB
00:00:03 3291MB | P reference (autobump) 0.10MB
00:00:03 3291MB | N reference (autobump) 0.03MB
00:00:03 3291MB | uniform indices 0.03MB
00:00:03 3291MB | userdata 0.01MB
00:00:03 3291MB | GPU memory use 3.13MB
00:00:03 3291MB | vertex indices 0.74MB
00:00:03 3291MB | normals 0.23MB
00:00:03 3291MB | normal indices 0.73MB
00:00:03 3291MB | uv coords 0.16MB
00:00:03 3291MB | uv coords idxs 0.74MB
00:00:03 3291MB | N reference (autobump) 0.10MB
00:00:03 3291MB | uniform indices 0.08MB
00:00:03 3291MB | other 0.02MB
00:00:03 3291MB | largest polymeshes by triangle count
00:00:03 3291MB | 17680 tris -- /Donut/Dough/DoughShape
00:00:03 3291MB | 13712 tris -- /Donut/Icing/IcingShape
00:00:03 3291MB | 380 tris -- /SceneSetup/pPlane1/pPlaneShape1
00:00:03 3291MB | 110 tris -- /SceneSetup/pCube1/pCubeShape1
00:00:03 3291MB | 48 tris -- /Donut/Sprinkles/polySurface4/polySurfaceShape4
00:00:03 3291MB | OpenImageIO Texture statistics
00:00:03 3291MB | Options: gray_to_rgb=1 flip_t=0 max_tile_channels=6
00:00:03 3291MB | Queries/batches :
00:00:03 3291MB | texture : 9084 queries in 9084 batches
00:00:03 3291MB | texture 3d : 0 queries in 0 batches
00:00:03 3291MB | shadow : 0 queries in 0 batches
00:00:03 3291MB | environment : 0 queries in 0 batches
00:00:03 3291MB | gettextureinfo : 0 queries
00:00:03 3291MB | Interpolations :
00:00:03 3291MB | closest : 4
00:00:03 3291MB | bilinear : 28052
00:00:03 3291MB | bicubic : 5289
00:00:03 3291MB | Average anisotropic probes : 1.89
00:00:03 3291MB | Max anisotropy in the wild : 85.6
00:00:03 3291MB |
00:00:03 3291MB | OpenImageIO ImageCache statistics (000000D574D48040) ver 2.2.1
00:00:03 3291MB | Options: max_memory_MB=4096.0 max_open_files=1536 autotile=0
00:00:03 3291MB | autoscanline=1 automip=0 forcefloat=0 accept_untiled=1
00:00:03 3291MB | accept_unmipped=1 deduplicate=1 unassociatedalpha=0
00:00:03 3291MB | failure_retries=0
00:00:03 3291MB | Images : 4 unique
00:00:03 3291MB | ImageInputs : 4 created, 2 current, 2 peak
00:00:03 3291MB | Total pixel data size of all images referenced : 9.5 MB
00:00:03 3291MB | Total actual file size of all images referenced : 1.5 MB
00:00:03 3291MB | Pixel data read : 2.3 MB
00:00:03 3291MB | File I/O time : 0.1s (0.0s average per thread, for 13 threads)
00:00:03 3291MB | File open time only : 0.0s
00:00:03 3291MB | ImageInput mutex locking time : 0.0s
00:00:03 3291MB | Tiles: 173 created, 164 current, 164 peak
00:00:03 3291MB | total tile requests : 46725
00:00:03 3291MB | micro-cache misses : 660 (1.41252%)
00:00:03 3291MB | main cache misses : 173 (0.370251%)
00:00:03 3291MB | redundant reads: 3 tiles, 40 KB
00:00:03 3291MB | Peak cache memory : 2.3 MB
00:00:03 3291MB | Image file statistics:
00:00:03 3291MB | opens tiles MB read --redundant-- I/O time res File
00:00:03 3291MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.jpg
00:00:03 3291MB | 2 1 99 0.8 ( 2 0.0) 0.0s 1200x 500x1.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.tx MIP-COUNT[55,27,10,3,2,0,0,0,0,0,2]
00:00:03 3291MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Texture.jpg
00:00:03 3291MB | 4 1 65 1.5 ( 1 0.0) 0.0s 1200x 500x3.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Texture.tx MIP-COUNT[24,19,11,3,2,1,1,1,1,1,1]
00:00:03 3291MB |
00:00:03 3291MB | Tot: 4 164 2.3 ( 3 0.0) 0.1s
00:00:03 3291MB | 2 were constant-valued in all pixels
00:00:03 3291MB | Broken or invalid files: 0
00:00:03 3291MB | number of warnings, warning type:
00:00:03 3291MB | 1: [disp] %s: padding is at least %.3gx smaller than it should be! given disp_padding: %.9g, recommended: %.9g
00:00:03 3291MB | performance warnings:
00:00:03 3291MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:03 3291MB | [color_manager] rendering color space is "ACEScg"
00:00:03 3291MB |
00:00:03 3291MB | rendering image at 2048 x 2048, -2 AA samples
00:00:03 3291MB | AA samples max 0
00:00:03 3291MB | AA adaptive threshold 0.015
00:00:03 3291MB | AA sample clamp <disabled>
00:00:03 3291MB | diffuse samples 1 / depth 3
00:00:03 3291MB | specular samples 2 / depth 2
00:00:03 3291MB | transmission samples 2 / depth 9
00:00:03 3291MB | volume indirect <disabled by depth>
00:00:03 3291MB | total depth 10
00:00:03 3291MB | bssrdf samples 2
00:00:03 3291MB | transparency depth 11
00:00:03 3291MB | initializing 176 nodes ...
00:00:03 3291MB | creating root object list ...
00:00:03 3291MB | node initialization done in 0:00.00 (multithreaded)
00:00:03 3291MB | updating 176 nodes ...
00:00:03 3291MB | scene bounds: (-89.5046997 -0.226797104 -159.059036) -> (89.5046997 118.745636 159.059357)
00:00:03 3291MB | node update done in 0:00.00 (multithreaded)
00:00:03 3291MB | [gpu] updating 176 nodes ...
00:00:03 3291MB | [aov] parsing 2 output statements ...
00:00:03 3291MB | [aov] registered driver: "arv_display" (driver_arv)
00:00:03 3291MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:03 3291MB | [aov] * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:03 3291MB | [aov] done preparing 4 AOVs for 2 outputs to 1 driver (0 deep AOVs)
00:00:03 3291MB | starting render ...
00:00:03 3291MB | [gpu] building scene and compiling shaders ...
00:00:03 3291MB | [gpu] building scene and compiling shaders done in 0:00.000
00:00:04 3322MB | render done in 0:00.997
00:00:04 3322MB |
00:00:04 3322MB | -----------------------------------------------------------------------------------
00:00:04 3322MB | scene creation time 0:00.29 machine utilization (11.50%)
00:00:04 3322MB | plugin loading 0:00.12
00:00:04 3322MB | unaccounted 0:00.16
00:00:04 3322MB | frame time 0:01.00 machine utilization (40.59%)
00:00:04 3322MB | rendering 0:00.99
00:00:04 3322MB | output driver 0:00.01
00:00:04 3322MB | pixel rendering 0:00.97
00:00:04 3322MB | top session self-times by category
00:00:04 3322MB | worker waiting 0:03.35 (74.22%)
00:00:04 3322MB | accumulateBucketSamples 0:00.35 ( 7.79%)
00:00:04 3322MB | GPU iteration 0:00.30 ( 6.72%)
00:00:04 3322MB | OptiX initialization 0:00.09 ( 2.16%)
00:00:04 3322MB | RenderBucket 0:00.06 ( 1.42%)
00:00:04 3322MB | create_optix_context 0:00.05 ( 1.15%)
00:00:04 3322MB | top session self-times by node
00:00:04 3322MB | peak CPU memory used 3322.57MB
00:00:04 3322MB | at startup 1551.93MB
00:00:04 3322MB | plugins 20.49MB
00:00:04 3322MB | AOV samples 17.93MB
00:00:04 3322MB | output buffers 0.77MB
00:00:04 3322MB | node overhead 0.12MB
00:00:04 3322MB | message passing 0.01MB
00:00:04 3322MB | memory pools 12.05MB
00:00:04 3322MB | geometry 0.95MB
00:00:04 3322MB | polymesh 0.95MB
00:00:04 3322MB | strings 24.25MB
00:00:04 3322MB | texture cache 2.89MB
00:00:04 3322MB | profiler 0.03MB
00:00:04 3322MB | unaccounted 1691.17MB (note: interactive session)
00:00:04 3322MB | output buffers 160.00MB
00:00:04 3322MB | geometry 3.13MB
00:00:04 3322MB | polymesh 3.13MB
00:00:04 3322MB | texture cache 2.51MB
00:00:04 3322MB | unaccounted -165.64MB
00:00:04 3322MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
00:00:04 3322MB | camera 264560 ( 0.01, 1.00) ( 1.64%) ( 0.99) ( 1)
00:00:04 3322MB | shadow 15555006 ( 0.84, 58.80) ( 96.23%) ( 0.22) ( 1)
00:00:04 3322MB | diffuse_reflect 332745 ( 0.02, 1.26) ( 2.06%) ( 0.28) ( 1)
00:00:04 3322MB | specular_reflect 12038 ( 0.00, 0.05) ( 0.07%) ( 0.48) ( 1)
00:00:04 3322MB | total 16164349 ( 0.88, 61.10) (100.00%) ( 0.23) ( 1)
00:00:04 3322MB | by ray depth: 0 1 2 3 4 5
00:00:04 3322MB | total 96.3% 2.7% 0.7% 0.2% 0.0% 0.0%
00:00:04 3322MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:04 3322MB | lists 1 ( 0.0%) ( 0) ( 0.00, 0.00)
00:00:04 3322MB | polymeshes 144 (100.0%) ( 0) ( 1.10, 0.95)
00:00:04 3322MB | geometric elements ( min) ( avg.) ( max)
00:00:04 3322MB | polygons 20135 ( 30) ( 139.8) ( 8840)
00:00:04 3322MB | triangle tessellation ( min) ( avg.) ( max) (/ element) (% total)
00:00:04 3322MB | polymeshes 38602 ( 48) ( 268.1) ( 17680) ( 1.92) (100.00%)
00:00:04 3322MB | unique triangles 38602
00:00:04 3322MB | CPU memory use 0.95MB
00:00:04 3322MB | vertices 0.23MB
00:00:04 3322MB | vertex indices 0.11MB
00:00:04 3322MB | polygon base offsets 0.00MB
00:00:04 3322MB | polygon IDs 0.00MB
00:00:04 3322MB | triangulation 0.00MB
00:00:04 3322MB | packed normals 0.08MB
00:00:04 3322MB | normal indices 0.11MB
00:00:04 3322MB | uv coords 0.09MB
00:00:04 3322MB | uv coords idxs 0.12MB
00:00:04 3322MB | P reference (autobump) 0.10MB
00:00:04 3322MB | N reference (autobump) 0.03MB
00:00:04 3322MB | uniform indices 0.03MB
00:00:04 3322MB | userdata 0.01MB
00:00:04 3322MB | GPU memory use 3.13MB
00:00:04 3322MB | vertex indices 0.74MB
00:00:04 3322MB | normals 0.23MB
00:00:04 3322MB | normal indices 0.73MB
00:00:04 3322MB | uv coords 0.16MB
00:00:04 3322MB | uv coords idxs 0.74MB
00:00:04 3322MB | N reference (autobump) 0.10MB
00:00:04 3322MB | uniform indices 0.08MB
00:00:04 3322MB | other 0.02MB
00:00:04 3322MB | OpenImageIO Texture statistics
00:00:04 3322MB | Options: gray_to_rgb=1 flip_t=0 max_tile_channels=6
00:00:04 3322MB | Queries/batches :
00:00:04 3322MB | texture : 9084 queries in 9084 batches
00:00:04 3322MB | texture 3d : 0 queries in 0 batches
00:00:04 3322MB | shadow : 0 queries in 0 batches
00:00:04 3322MB | environment : 0 queries in 0 batches
00:00:04 3322MB | gettextureinfo : 0 queries
00:00:04 3322MB | Interpolations :
00:00:04 3322MB | closest : 4
00:00:04 3322MB | bilinear : 28052
00:00:04 3322MB | bicubic : 5289
00:00:04 3322MB | Average anisotropic probes : 1.89
00:00:04 3322MB | Max anisotropy in the wild : 85.6
00:00:04 3322MB |
00:00:04 3322MB | OpenImageIO ImageCache statistics (000000D574D48040) ver 2.2.1
00:00:04 3322MB | Options: max_memory_MB=4096.0 max_open_files=1536 autotile=0
00:00:04 3322MB | autoscanline=1 automip=0 forcefloat=0 accept_untiled=1
00:00:04 3322MB | accept_unmipped=1 deduplicate=1 unassociatedalpha=0
00:00:04 3322MB | failure_retries=0
00:00:04 3322MB | Images : 4 unique
00:00:04 3322MB | ImageInputs : 4 created, 2 current, 2 peak
00:00:04 3322MB | Total pixel data size of all images referenced : 9.5 MB
00:00:04 3322MB | Total actual file size of all images referenced : 1.5 MB
00:00:04 3322MB | Pixel data read : 2.9 MB
00:00:04 3322MB | File I/O time : 0.1s (0.0s average per thread, for 13 threads)
00:00:04 3322MB | File open time only : 0.0s
00:00:04 3322MB | ImageInput mutex locking time : 0.0s
00:00:04 3322MB | Tiles: 207 created, 196 current, 196 peak
00:00:04 3322MB | total tile requests : 57017
00:00:04 3322MB | micro-cache misses : 917 (1.60829%)
00:00:04 3322MB | main cache misses : 207 (0.36305%)
00:00:04 3322MB | redundant reads: 4 tiles, 64 KB
00:00:04 3322MB | Peak cache memory : 2.9 MB
00:00:04 3322MB | Image file statistics:
00:00:04 3322MB | opens tiles MB read --redundant-- I/O time res File
00:00:04 3322MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.jpg
00:00:04 3322MB | 2 1 109 0.9 ( 2 0.0) 0.0s 1200x 500x1.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.tx MIP-COUNT[64,28,10,3,2,0,0,0,0,0,2]
00:00:04 3322MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Texture.jpg
00:00:04 3322MB | 4 1 87 2.0 ( 2 0.0) 0.1s 1200x 500x3.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Texture.tx MIP-COUNT[36,29,11,3,2,1,1,1,1,1,1]
00:00:04 3322MB |
00:00:04 3322MB | Tot: 4 196 2.9 ( 4 0.1) 0.1s
00:00:04 3322MB | 2 were constant-valued in all pixels
00:00:04 3322MB | Broken or invalid files: 0
00:00:04 3322MB | number of warnings, warning type:
00:00:04 3322MB | 1: [disp] %s: padding is at least %.3gx smaller than it should be! given disp_padding: %.9g, recommended: %.9g
00:00:04 3322MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:04 3322MB | [color_manager] rendering color space is "ACEScg"
00:00:04 3322MB |
00:00:04 3322MB | rendering image at 2048 x 2048, -1 AA samples
00:00:04 3322MB | AA samples max 0
00:00:04 3322MB | AA adaptive threshold 0.015
00:00:04 3322MB | AA sample clamp <disabled>
00:00:04 3322MB | diffuse samples 1 / depth 3
00:00:04 3322MB | specular samples 2 / depth 2
00:00:04 3322MB | transmission samples 2 / depth 9
00:00:04 3322MB | volume indirect <disabled by depth>
00:00:04 3322MB | total depth 10
00:00:04 3322MB | bssrdf samples 2
00:00:04 3322MB | transparency depth 11
00:00:04 3322MB | node initialization done in 0:00.00 (multithreaded)
00:00:04 3322MB | updating 176 nodes ...
00:00:04 3322MB | node update done in 0:00.00 (multithreaded)
00:00:04 3322MB | [aov] parsing 2 output statements ...
00:00:04 3322MB | [aov] registered driver: "arv_display" (driver_arv)
00:00:04 3322MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:04 3322MB | [aov] * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:04 3322MB | [aov] done preparing 4 AOVs for 2 outputs to 1 driver (0 deep AOVs)
00:00:04 3322MB | starting render ...
00:00:04 3322MB | [gpu] building scene and compiling shaders ...
00:00:04 3322MB | [gpu] building scene and compiling shaders done in 0:00.000
00:00:06 3374MB | render done in 0:02.282
00:00:06 3374MB |
00:00:06 3374MB | -----------------------------------------------------------------------------------
00:00:06 3374MB | scene creation time 0:00.29 machine utilization (11.50%)
00:00:06 3374MB | plugin loading 0:00.12
00:00:06 3374MB | unaccounted 0:00.16
00:00:06 3374MB | frame time 0:02.28 machine utilization (25.30%)
00:00:06 3374MB | rendering 0:02.28
00:00:06 3374MB | output driver 0:00.02
00:00:06 3374MB | pixel rendering 0:02.25
00:00:06 3374MB | top session self-times by category
00:00:06 3374MB | worker waiting 0:05.42 (75.90%)
00:00:06 3374MB | GPU iteration 0:00.61 ( 8.61%)
00:00:06 3374MB | accumulateBucketSamples 0:00.46 ( 6.51%)
00:00:06 3374MB | RenderBucket 0:00.13 ( 1.92%)
00:00:06 3374MB | OptiX initialization 0:00.09 ( 1.37%)
00:00:06 3374MB | driver_process_bucket (arv_display) 0:00.07 ( 0.99%)
00:00:06 3374MB | top session self-times by node
00:00:06 3374MB | driver_arv:arv_display (driver_process_bucket) 0:00.07 ( 0.99%)
00:00:06 3374MB | peak CPU memory used 3374.68MB
00:00:06 3374MB | at startup 1551.93MB
00:00:06 3374MB | plugins 20.49MB
00:00:06 3374MB | AOV samples 63.38MB
00:00:06 3374MB | output buffers 0.77MB
00:00:06 3374MB | node overhead 0.12MB
00:00:06 3374MB | message passing 0.01MB
00:00:06 3374MB | memory pools 12.05MB
00:00:06 3374MB | geometry 0.95MB
00:00:06 3374MB | polymesh 0.95MB
00:00:06 3374MB | strings 24.25MB
00:00:06 3374MB | texture cache 3.92MB
00:00:06 3374MB | profiler 0.03MB
00:00:06 3374MB | unaccounted 1696.79MB (note: interactive session)
00:00:06 3374MB | output buffers 160.00MB
00:00:06 3374MB | geometry 3.13MB
00:00:06 3374MB | polymesh 3.13MB
00:00:06 3374MB | texture cache 4.51MB
00:00:06 3374MB | unaccounted -167.64MB
00:00:06 3374MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
00:00:06 3374MB | camera 1051753 ( 0.07, 1.00) ( 1.63%) ( 1.00) ( 1)
00:00:06 3374MB | shadow 62186999 ( 4.20, 59.13) ( 96.24%) ( 0.22) ( 1)
00:00:06 3374MB | diffuse_reflect 1328940 ( 0.09, 1.26) ( 2.06%) ( 0.28) ( 1)
00:00:06 3374MB | specular_reflect 47322 ( 0.00, 0.04) ( 0.07%) ( 0.47) ( 1)
00:00:06 3374MB | total 64615014 ( 4.37, 61.44) (100.00%) ( 0.23) ( 1)
00:00:06 3374MB | by ray depth: 0 1 2 3 4 5
00:00:06 3374MB | total 96.3% 2.7% 0.7% 0.2% 0.0% 0.0%
00:00:06 3374MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:06 3374MB | lists 1 ( 0.0%) ( 0) ( 0.00, 0.00)
00:00:06 3374MB | polymeshes 144 (100.0%) ( 0) ( 1.10, 0.95)
00:00:06 3374MB | geometric elements ( min) ( avg.) ( max)
00:00:06 3374MB | polygons 20135 ( 30) ( 139.8) ( 8840)
00:00:06 3374MB | triangle tessellation ( min) ( avg.) ( max) (/ element) (% total)
00:00:06 3374MB | polymeshes 38602 ( 48) ( 268.1) ( 17680) ( 1.92) (100.00%)
00:00:06 3374MB | unique triangles 38602
00:00:06 3374MB | CPU memory use 0.95MB
00:00:06 3374MB | vertices 0.23MB
00:00:06 3374MB | vertex indices 0.11MB
00:00:06 3374MB | polygon base offsets 0.00MB
00:00:06 3374MB | polygon IDs 0.00MB
00:00:06 3374MB | triangulation 0.00MB
00:00:06 3374MB | packed normals 0.08MB
00:00:06 3374MB | normal indices 0.11MB
00:00:06 3374MB | uv coords 0.09MB
00:00:06 3374MB | uv coords idxs 0.12MB
00:00:06 3374MB | P reference (autobump) 0.10MB
00:00:06 3374MB | N reference (autobump) 0.03MB
00:00:06 3374MB | uniform indices 0.03MB
00:00:06 3374MB | userdata 0.01MB
00:00:06 3374MB | GPU memory use 3.13MB
00:00:06 3374MB | vertex indices 0.74MB
00:00:06 3374MB | normals 0.23MB
00:00:06 3374MB | normal indices 0.73MB
00:00:06 3374MB | uv coords 0.16MB
00:00:06 3374MB | uv coords idxs 0.74MB
00:00:06 3374MB | N reference (autobump) 0.10MB
00:00:06 3374MB | uniform indices 0.08MB
00:00:06 3374MB | other 0.02MB
00:00:06 3374MB | OpenImageIO Texture statistics
00:00:06 3374MB | Options: gray_to_rgb=1 flip_t=0 max_tile_channels=6
00:00:06 3374MB | Queries/batches :
00:00:06 3374MB | texture : 9084 queries in 9084 batches
00:00:06 3374MB | texture 3d : 0 queries in 0 batches
00:00:06 3374MB | shadow : 0 queries in 0 batches
00:00:06 3374MB | environment : 0 queries in 0 batches
00:00:06 3374MB | gettextureinfo : 0 queries
00:00:06 3374MB | Interpolations :
00:00:06 3374MB | closest : 4
00:00:06 3374MB | bilinear : 28052
00:00:06 3374MB | bicubic : 5289
00:00:06 3374MB | Average anisotropic probes : 1.89
00:00:06 3374MB | Max anisotropy in the wild : 85.6
00:00:06 3374MB |
00:00:06 3374MB | OpenImageIO ImageCache statistics (000000D574D48040) ver 2.2.1
00:00:06 3374MB | Options: max_memory_MB=4096.0 max_open_files=1536 autotile=0
00:00:06 3374MB | autoscanline=1 automip=0 forcefloat=0 accept_untiled=1
00:00:06 3374MB | accept_unmipped=1 deduplicate=1 unassociatedalpha=0
00:00:06 3374MB | failure_retries=0
00:00:06 3374MB | Images : 4 unique
00:00:06 3374MB | ImageInputs : 4 created, 2 current, 2 peak
00:00:06 3374MB | Total pixel data size of all images referenced : 9.5 MB
00:00:06 3374MB | Total actual file size of all images referenced : 1.5 MB
00:00:06 3374MB | Pixel data read : 3.9 MB
00:00:06 3374MB | File I/O time : 0.1s (0.0s average per thread, for 13 threads)
00:00:06 3374MB | File open time only : 0.0s
00:00:06 3374MB | ImageInput mutex locking time : 0.0s
00:00:06 3374MB | Tiles: 258 created, 245 current, 245 peak
00:00:06 3374MB | total tile requests : 70569
00:00:06 3374MB | micro-cache misses : 1239 (1.75573%)
00:00:06 3374MB | main cache misses : 258 (0.3656%)
00:00:06 3374MB | redundant reads: 5 tiles, 72 KB
00:00:06 3374MB | Peak cache memory : 3.9 MB
00:00:06 3374MB | Image file statistics:
00:00:06 3374MB | opens tiles MB read --redundant-- I/O time res File
00:00:06 3374MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.jpg
00:00:06 3374MB | 2 1 117 0.9 ( 3 0.0) 0.0s 1200x 500x1.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.tx MIP-COUNT[72,28,10,3,2,0,0,0,0,0,2]
00:00:06 3374MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Texture.jpg
00:00:06 3374MB | 4 1 128 3.0 ( 2 0.0) 0.1s 1200x 500x3.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Texture.tx MIP-COUNT[71,35,11,3,2,1,1,1,1,1,1]
00:00:06 3374MB |
00:00:06 3374MB | Tot: 4 245 3.9 ( 5 0.1) 0.1s
00:00:06 3374MB | 2 were constant-valued in all pixels
00:00:06 3374MB | Broken or invalid files: 0
00:00:06 3374MB | number of warnings, warning type:
00:00:06 3374MB | 1: [disp] %s: padding is at least %.3gx smaller than it should be! given disp_padding: %.9g, recommended: %.9g
00:00:06 3374MB | performance warnings:
00:00:06 3374MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:06 3374MB | [color_manager] rendering color space is "ACEScg"
00:00:06 3374MB |
00:00:06 3374MB | rendering image at 2048 x 2048, 4 AA samples
00:00:06 3374MB | AA samples max 20
00:00:06 3374MB | AA adaptive threshold 0.015
00:00:06 3374MB | AA sample clamp <disabled>
00:00:06 3374MB | diffuse samples 2 / depth 3
00:00:06 3374MB | specular samples 2 / depth 2
00:00:06 3374MB | transmission samples 2 / depth 9
00:00:06 3374MB | volume indirect <disabled by depth>
00:00:06 3374MB | total depth 10
00:00:06 3374MB | bssrdf samples 2
00:00:06 3374MB | transparency depth 11
00:00:06 3374MB | node initialization done in 0:00.00 (multithreaded)
00:00:06 3374MB | updating 176 nodes ...
00:00:06 3374MB | node update done in 0:00.00 (multithreaded)
00:00:06 3374MB | [aov] parsing 2 output statements ...
00:00:06 3374MB | [aov] registered driver: "arv_display" (driver_arv)
00:00:06 3374MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:06 3374MB | [aov] * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:06 3374MB | [aov] done preparing 4 AOVs for 2 outputs to 1 driver (0 deep AOVs)
00:00:06 3054MB | starting render ...
00:00:06 3054MB | [gpu] building scene and compiling shaders ...
00:00:06 3054MB | [gpu] building scene and compiling shaders done in 0:00.000
00:00:09 3318MB ERROR | [gpu] an error happened during rendering. OptiX error is: Unknown error (Details: Function "_rtContextLaunch2D" caught exception: Encountered a CUDA error: cudaDriver().CuEventSynchronize( m_event ) returned (702): Launch timeout, file: <internal>, line: 0)
GPU 0 had 142MB free before rendering started and 39MB free when crash occurred
GPU 1 had 118MB free before rendering started and 39MB free when crash occurred
GPU errors are sometimes due to a GPU not having enough remaining free memory. To see if this is what happened here, try simplifying your scene or running on a GPU with more free RAM to see if it solves the crash. Otherwise, upgrading to the latest nvidia gpu driver and Arnold core (available from www.arnoldrenderer.com) might fix the crash
00:00:09 3318MB | render done
Message 12 of 13
Christoph_Schaedl
First use only one graphics card. The slower one does only slow your rendertime. Cause it does render the half of the image.
That try to hide objects in your scene. First try only the background. Than bring in one by one.
Message 13 of 13
Alright I tried a few renders using just my GTX 1070.  The GTX 1070 on its own can render up to 1k resolution (see attatched image) but it crashes if I try to render in 2k or above.  The GTX 1050 on its own can only render up to 720p.   Here is a screenshot of my scene and the GTX 1070 render in 1k.  As you can see it is just a simple scene with a donut, so I would have thought that my GTX 1070 would have been able to render this in a resolution above 2k without any problems.   I also tried rendering just the background and podium in 4k, without the donut and it still crashed
Here is the error log for the 4k render I tried with just my GTX 1070  (I couldnt figure out how to hide the donut sprinkles without clicking on each one individually):
00:00:00 1762MB | log started Thu Jul 1 17:48:02 2021
00:00:00 1762MB | Arnold 6.2.0.1 [903992ac] windows clang-10.0.1 oiio-2.2.1 osl-1.11.6 vdb-7.1.1 clm-2.0.0.235 rlm-12.4.2 optix-6.6.0 2021/02/09 10:40:42
00:00:00 1762MB | host application: MtoA 4.2.1 d5445900 (master) Maya 2022
00:00:00 1762MB | running on vr-pc, pid=5084
00:00:00 1762MB | 1 x Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (4 cores, 8 logical) with 16229MB
00:00:00 1765MB | NVIDIA driver version 471.11 (Optix 60801)
00:00:00 1765MB | GPU 0: NVIDIA GeForce GTX 1070 @ 1784MHz (compute 6.1) with 8192MB (39MB available) (NVLink:0)
00:00:00 1765MB | GPU 1: NVIDIA GeForce GTX 1050 @ 1493MHz (compute 6.1) with 2048MB (39MB available) (NVLink:0)
00:00:00 1765MB | Windows 8.1 (version 6.3, build 9600)
00:00:00 1765MB | soft limit for open files is set at 2048
00:00:00 1765MB |
00:00:00 1766MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2022/shaders ...
00:00:00 1766MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderDiffuseColorAdapter uses Arnold 6.2.0.1
00:00:00 1766MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularWeightAdapter uses Arnold 6.2.0.1
00:00:00 1766MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularGlossAdapter uses Arnold 6.2.0.1
00:00:00 1766MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionWeightAdapter uses Arnold 6.2.0.1
00:00:00 1766MB | hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionSpreadAdapter uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkFloatConstant uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkFloatComposite uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkFloatCondition uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkFloatCorrect uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkFloatLogic uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkFloatMask uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkFloatMath uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkColorComposite uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkColorCondition uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkColorConstant uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkColorCorrect uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkColorLogic uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkColorMask uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkColorMath uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkChannels uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkPremultiply uses Arnold 6.2.0.1
00:00:00 1766MB | lookdevkit_shaders.dll: ldkSimplexNoise uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaMultiplyDivide uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaClamp uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaGammaCorrect uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaCondition uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaReverse uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaBlendColors uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSamplerInfo1D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSamplerInfo2D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaPlusMinusAverage1D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaPlusMinusAverage2D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaPlusMinusAverage3D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaRemapValueToValue uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaRemapValueToColor uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaRemapColor uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaFile uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaPlace2DTexture uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaRamp uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaProjection uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaChecker uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaBulge uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaCloth uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaGrid uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaFractal uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaNoise uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaPlace3DTexture uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaRgbToHsv uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaHsvToRgb uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaLuminance uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaCloud uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaCloudAlpha uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSnow uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaContrast uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaLayeredTexture uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSolidFractal uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaVolumeNoise uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaBrownian uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaStucco uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaRemapHsv uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSetRange uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaImagePlane uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSurfaceShader uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaColorToFloat uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaVectorToFloat uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaPointToFloat uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaPoint2ToFloat uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaWriteColor uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAovWriteColor uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaWriteFloat uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAovWriteFloat uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaEnvSphere uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAnimFloat uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAnimPoint uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAnimVector uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAnimColor uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAnimMatrix uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaUserDataVector uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaUserDataColor uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaShadingEngine uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSamplerInfo3D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAovWriteVector uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaAovWriteVector2 uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaNormalDisplacement uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaVectorDisplacement uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaUserDataBool uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaHair uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaMeshLightMaterial uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaUserDataVec2 uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaBump2D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaFluid uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaMarble uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaMountain uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaWater uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaCrater uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaLeather uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaGranite uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaRock uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSingleShadingSwitch uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaDoubleShadingSwitch uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaTripleShadingSwitch uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaQuadShadingSwitch uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaFluidData uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaFluidTexture2D uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaSurfaceLuminance uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MtoaCameraUvMapper uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_shaders.dll: MayaFlatClosure uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyAbsFloatOverride uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyAbs2FloatsOverride uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyAbs3FloatsOverride uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyAbsIntOverride uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyRelFloatOverride uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyRel2FloatsOverride uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyRel3FloatsOverride uses Arnold 6.2.0.1
00:00:00 1766MB | renderSetup_shaders.dll: applyRelIntOverride uses Arnold 6.2.0.1
00:00:00 1766MB | xgenSpline_shaders.dll: XGenHairMapping uses Arnold 6.2.0.1
00:00:00 1766MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2022/procedurals ...
00:00:00 1766MB | mtoa_ParticleInstancer_proc.dll: particleInstancer uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_ParticleVolume_proc.dll: volume_particle uses Arnold 6.2.0.1
00:00:00 1766MB | mtoa_ParticleVolume_proc.dll: implicit_particle uses Arnold 6.2.0.1
00:00:00 1766MB | xgenSpline_procedural.dll: xgenProcedural uses Arnold 6.2.0.1
00:00:00 1766MB | xgen_procedural.dll: xgen_procedural uses Arnold 6.2.0.1
00:00:00 1766MB | loaded 121 plugins from 9 lib(s) in 0:00.02
00:00:00 1766MB | loading plugins from C:\Program Files\Autodesk\Arnold\maya2022\bin\..\plugins ...
00:00:00 1766MB | alembic_proc.dll: alembic uses Arnold 6.2.0.1
00:00:00 1766MB | cryptomatte.dll: cryptomatte uses Arnold 6.2.0.1
00:00:00 1766MB | cryptomatte.dll: cryptomatte_filter uses Arnold 6.2.0.1
00:00:00 1766MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 6.2.0.1
00:00:00 1767MB | synColor_shaders.dll: color_manager_syncolor uses Arnold 6.2.0.1
00:00:00 1783MB | usd_proc.dll: usd uses Arnold 6.2.0.1
00:00:00 1783MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 1783MB | loading plugin: C:/Program Files/Autodesk/Bifrost/Maya2022/2.2.1.0/bifrost/arnold-6.2.0.0/arnold_bifrost.dll ...
00:00:00 1783MB | arnold_bifrost.dll: bifrost_graph uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_object uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_multires_volume uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_multires_implicit uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_volume uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_points uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_implicit uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_polymesh uses Arnold 6.2.0.0
00:00:00 1783MB | arnold_bifrost.dll: bifrost_blocks uses Arnold 6.2.0.0
00:00:00 1783MB | loaded 9 plugins from 1 lib(s) in 0:00.01
00:00:00 1784MB | [mtoa] RGBA attribute file1.defaultColor has no alpha component: exporting as RGBA
00:00:00 1784MB | [mtoa] RGBA attribute file2.defaultColor has no alpha component: exporting as RGBA
00:00:00 1787MB | [color_manager_ocio] using config file D:/Program Files/Autodesk/Maya2022/resources/OCIO-configs/Maya2022-default/config.ocio
00:00:00 1918MB |
00:00:00 1791MB | [AiMakeTx] maketx: no update required for "D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.tx"
00:00:00 1791MB | [AiMakeTx] maketx: no update required for "D:/Maya Projects/Practice/sourceimages/Dougnut Texture.tx"
00:00:00 1927MB | [gpu] setting OptiX disk cache location to: C:\Users\Connor\AppData\Local/NVIDIA/OptixCache/arnold
00:00:00 2020MB | GPU 0: NVIDIA GeForce GTX 1070 enabled
00:00:00 2020MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:00 2020MB | [color_manager] rendering color space is "ACEScg"
00:00:00 2040MB |
00:00:00 2040MB | there are 3 lights and 145 objects:
00:00:00 2040MB | 2 persp_camera
00:00:00 2040MB | 3 ortho_camera
00:00:00 2040MB | 3 quad_light
00:00:00 2040MB | 2 image
00:00:00 2040MB | 1 utility
00:00:00 2040MB | 9 standard_surface
00:00:00 2040MB | 1 color_correct
00:00:00 2040MB | 1 range
00:00:00 2040MB | 1 driver_exr
00:00:00 2040MB | 2 gaussian_filter
00:00:00 2040MB | 1 closest_filter
00:00:00 2040MB | 144 polymesh
00:00:00 2040MB | 1 list_aggregate
00:00:00 2040MB | 1 color_manager_ocio
00:00:00 2040MB | 1 renderview_display
00:00:00 2040MB | 1 driver_arv
00:00:00 2040MB |
00:00:00 2040MB | rendering image at 4096 x 4096, -3 AA samples
00:00:00 2040MB | AA samples max 0
00:00:00 2040MB | AA adaptive threshold 0.015
00:00:00 2040MB | AA sample clamp <disabled>
00:00:00 2040MB | diffuse samples 2 / depth 3
00:00:00 2040MB | specular samples 2 / depth 2
00:00:00 2040MB | transmission samples 2 / depth 9
00:00:00 2040MB | volume indirect <disabled by depth>
00:00:00 2040MB | total depth 10
00:00:00 2040MB | bssrdf samples 2
00:00:00 2040MB | transparency depth 11
00:00:00 2040MB | initializing 175 nodes ...
00:00:00 2042MB | creating root object list ...
00:00:00 2042MB | node initialization done in 0:00.00 (multithreaded)
00:00:00 2042MB | updating 176 nodes ...
00:00:00 2045MB | /HairLight/HairLightShape: quad_light using 5 samples, 2 volume samples
00:00:00 2045MB | /KeyLight/KeyLightShape: quad_light using 5 samples, 2 volume samples
00:00:00 2046MB | /FillLight/FillLightShape: quad_light using 5 samples, 2 volume samples
00:00:00 2055MB | scene bounds: (-89.5046997 -0.226797104 -159.059036) -> (89.5046997 118.745636 159.059357)
00:00:00 2055MB | node update done in 0:00.02 (multithreaded)
00:00:00 2055MB | [gpu] preparing 176 nodes ...
00:00:00 2057MB WARNING | [disp] /Donut/Dough/DoughShape: padding is at least 10x smaller than it should be! given disp_padding: 0, recommended: 0.0587291718
00:00:01 2073MB | [gpu] updating 176 nodes ...
00:00:01 2100MB | [aov] parsing 2 output statements ...
00:00:01 2100MB | [aov] registered driver: "arv_display" (driver_arv)
00:00:01 2100MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:01 2100MB | [aov] * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:01 2100MB | [aov] done preparing 4 AOVs for 2 outputs to 1 driver (0 deep AOVs)
00:00:01 2548MB | starting render ...
00:00:01 2617MB | [gpu] building scene and compiling shaders ...
00:00:02 2679MB | [gpu] building scene and compiling shaders done in 0:00.483
00:00:04 4968MB | render done in 0:03.335
00:00:04 4967MB | render done
00:00:04 4967MB |
00:00:04 4967MB | -----------------------------------------------------------------------------------
00:00:04 4967MB | scene creation time 0:00.35 machine utilization (10.16%)
00:00:04 4967MB | plugin loading 0:00.12
00:00:04 4967MB | unaccounted 0:00.22
00:00:04 4967MB | frame time 0:04.59 machine utilization (34.96%)
00:00:04 4967MB | node init 0:00.02
00:00:04 4967MB | displacement 0:00.01
00:00:04 4967MB | gpu prepare 0:00.18
00:00:04 4967MB | gpu update 0:00.45
00:00:04 4967MB | gpu jit compile / BVH 0:00.48
00:00:04 4967MB | rendering 0:02.85
00:00:04 4967MB | output driver 0:00.05
00:00:04 4967MB | pixel rendering 0:02.79
00:00:04 4967MB | unaccounted 0:00.58
00:00:04 4967MB | top session self-times by category
00:00:04 4967MB | worker waiting 0:02.82 (63.61%)
00:00:04 4967MB | accumulateBucketSamples 0:00.67 (15.22%)
00:00:04 4967MB | GPU iteration 0:00.23 ( 5.38%)
00:00:04 4967MB | renderFrame 0:00.16 ( 3.68%)
00:00:04 4967MB | RenderBucket 0:00.13 ( 3.10%)
00:00:04 4967MB | OptiX initialization 0:00.06 ( 1.55%)
00:00:04 4967MB | top session self-times by node
00:00:04 4967MB | peak CPU memory used 4968.21MB
00:00:04 4967MB | at startup 1765.91MB
00:00:04 4967MB | plugins 17.68MB
00:00:04 4967MB | AOV samples 22.90MB
00:00:04 4967MB | output buffers 0.77MB
00:00:04 4967MB | framebuffers 448.00MB
00:00:04 4967MB | node overhead 0.12MB
00:00:04 4967MB | message passing 0.01MB
00:00:04 4967MB | memory pools 12.05MB
00:00:04 4967MB | geometry 0.95MB
00:00:04 4967MB | polymesh 0.95MB
00:00:04 4967MB | strings 24.25MB
00:00:04 4967MB | texture cache 4.00MB
00:00:04 4967MB | profiler 0.04MB
00:00:04 4967MB | unaccounted 2671.53MB (note: interactive session)
00:00:04 4967MB | output buffers 640.00MB
00:00:04 4967MB | geometry 3.13MB
00:00:04 4967MB | polymesh 3.13MB
00:00:04 4967MB | texture cache 4.11MB
00:00:04 4967MB | unaccounted -647.25MB
00:00:04 4967MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
00:00:04 4967MB | camera 317374 ( 0.00, 1.00) ( 1.54%) ( 1.00) ( 1)
00:00:04 4967MB | shadow 19850354 ( 0.27, 62.55) ( 96.42%) ( 0.37) ( 1)
00:00:04 4967MB | diffuse_reflect 401459 ( 0.01, 1.26) ( 1.95%) ( 0.32) ( 1)
00:00:04 4967MB | specular_reflect 17943 ( 0.00, 0.06) ( 0.09%) ( 0.48) ( 1)
00:00:04 4967MB | total 20587130 ( 0.28, 64.87) (100.00%) ( 0.38) ( 1)
00:00:04 4967MB | by ray depth: 0 1 2 3 4 5
00:00:04 4967MB | total 96.2% 2.7% 0.8% 0.3% 0.0% 0.0%
00:00:04 4967MB | meshes 1
00:00:04 4967MB | shader calls 9080
00:00:04 4967MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:04 4967MB | lists 1 (100.0%) ( 0) ( 0.00, 0.00)
00:00:04 4967MB | polymeshes 144 (100.0%) ( 0) ( 1.10, 0.95)
00:00:04 4967MB | geometric elements ( min) ( avg.) ( max)
00:00:04 4967MB | polygons 20135 ( 30) ( 139.8) ( 8840)
00:00:04 4967MB | triangle tessellation ( min) ( avg.) ( max) (/ element) (% total)
00:00:04 4967MB | polymeshes 38602 ( 48) ( 268.1) ( 17680) ( 1.92) (100.00%)
00:00:04 4967MB | unique triangles 38602
00:00:04 4967MB | CPU memory use 0.95MB
00:00:04 4967MB | vertices 0.23MB
00:00:04 4967MB | vertex indices 0.11MB
00:00:04 4967MB | polygon base offsets 0.00MB
00:00:04 4967MB | polygon IDs 0.00MB
00:00:04 4967MB | triangulation 0.00MB
00:00:04 4967MB | packed normals 0.08MB
00:00:04 4967MB | normal indices 0.11MB
00:00:04 4967MB | uv coords 0.09MB
00:00:04 4967MB | uv coords idxs 0.12MB
00:00:04 4967MB | P reference (autobump) 0.10MB
00:00:04 4967MB | N reference (autobump) 0.03MB
00:00:04 4967MB | uniform indices 0.03MB
00:00:04 4967MB | userdata 0.01MB
00:00:04 4967MB | GPU memory use 3.13MB
00:00:04 4967MB | vertex indices 0.74MB
00:00:04 4967MB | normals 0.23MB
00:00:04 4967MB | normal indices 0.73MB
00:00:04 4967MB | uv coords 0.16MB
00:00:04 4967MB | uv coords idxs 0.74MB
00:00:04 4967MB | N reference (autobump) 0.10MB
00:00:04 4967MB | uniform indices 0.08MB
00:00:04 4967MB | other 0.02MB
00:00:04 4967MB | largest polymeshes by triangle count
00:00:04 4967MB | 17680 tris -- /Donut/Dough/DoughShape
00:00:04 4967MB | 13712 tris -- /Donut/Icing/IcingShape
00:00:04 4967MB | 380 tris -- /SceneSetup/pPlane1/pPlaneShape1
00:00:04 4967MB | 110 tris -- /SceneSetup/pCube1/pCubeShape1
00:00:04 4967MB | 48 tris -- /Donut/Sprinkles/polySurface4/polySurfaceShape4
00:00:04 4967MB | OpenImageIO Texture statistics
00:00:04 4967MB | Options: gray_to_rgb=1 flip_t=0 max_tile_channels=6
00:00:04 4967MB | Queries/batches :
00:00:04 4967MB | texture : 9084 queries in 9084 batches
00:00:04 4967MB | texture 3d : 0 queries in 0 batches
00:00:04 4967MB | shadow : 0 queries in 0 batches
00:00:04 4967MB | environment : 0 queries in 0 batches
00:00:04 4967MB | gettextureinfo : 0 queries
00:00:04 4967MB | Interpolations :
00:00:04 4967MB | closest : 4
00:00:04 4967MB | bilinear : 28052
00:00:04 4967MB | bicubic : 5289
00:00:04 4967MB | Average anisotropic probes : 1.89
00:00:04 4967MB | Max anisotropy in the wild : 85.6
00:00:04 4967MB |
00:00:04 4967MB | OpenImageIO ImageCache statistics (0000008FE414C040) ver 2.2.1
00:00:04 4967MB | Options: max_memory_MB=4096.0 max_open_files=1536 autotile=0
00:00:04 4967MB | autoscanline=1 automip=0 forcefloat=0 accept_untiled=1
00:00:04 4967MB | accept_unmipped=1 deduplicate=1 unassociatedalpha=0
00:00:04 4967MB | failure_retries=0
00:00:04 4967MB | Images : 4 unique
00:00:04 4967MB | ImageInputs : 4 created, 2 current, 2 peak
00:00:04 4967MB | Total pixel data size of all images referenced : 9.5 MB
00:00:04 4967MB | Total actual file size of all images referenced : 1.5 MB
00:00:04 4967MB | Pixel data read : 4.0 MB
00:00:04 4967MB | File I/O time : 0.1s (0.0s average per thread, for 13 threads)
00:00:04 4967MB | File open time only : 0.0s
00:00:04 4967MB | ImageInput mutex locking time : 0.0s
00:00:04 4967MB | Tiles: 243 created, 226 current, 226 peak
00:00:04 4967MB | total tile requests : 60261
00:00:04 4967MB | micro-cache misses : 985 (1.63456%)
00:00:04 4967MB | main cache misses : 243 (0.403246%)
00:00:04 4967MB | redundant reads: 3 tiles, 72 KB
00:00:04 4967MB | Peak cache memory : 4.0 MB
00:00:04 4967MB | Image file statistics:
00:00:04 4967MB | opens tiles MB read --redundant-- I/O time res File
00:00:04 4967MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.jpg
00:00:04 4967MB | 2 1 83 0.6 0.0s 1200x 500x1.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.tx MIP-COUNT[47,22,10,3,0,0,0,0,0,0,1]
00:00:04 4967MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Texture.jpg
00:00:04 4967MB | 4 1 143 3.4 ( 3 0.1) 0.1s 1200x 500x3.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Texture.tx MIP-COUNT[85,37,10,3,2,1,1,1,1,1,1]
00:00:04 4967MB |
00:00:04 4967MB | Tot: 4 226 4.0 ( 3 0.1) 0.1s
00:00:04 4967MB | 2 were constant-valued in all pixels
00:00:04 4967MB | Broken or invalid files: 0
00:00:04 4967MB | number of warnings, warning type:
00:00:04 4967MB | 1: [disp] %s: padding is at least %.3gx smaller than it should be! given disp_padding: %.9g, recommended: %.9g
00:00:04 4967MB | performance warnings:
00:00:04 4967MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:04 4967MB | [color_manager] rendering color space is "ACEScg"
00:00:04 4967MB |
00:00:04 4967MB | rendering image at 4096 x 4096, -2 AA samples
00:00:04 4967MB | AA samples max 0
00:00:04 4967MB | AA adaptive threshold 0.015
00:00:04 4967MB | AA sample clamp <disabled>
00:00:04 4967MB | diffuse samples 1 / depth 3
00:00:04 4967MB | specular samples 2 / depth 2
00:00:04 4967MB | transmission samples 2 / depth 9
00:00:04 4967MB | volume indirect <disabled by depth>
00:00:04 4967MB | total depth 10
00:00:04 4967MB | bssrdf samples 2
00:00:04 4967MB | transparency depth 11
00:00:04 4967MB | initializing 176 nodes ...
00:00:04 4967MB | creating root object list ...
00:00:04 4967MB | node initialization done in 0:00.00 (multithreaded)
00:00:04 4967MB | updating 176 nodes ...
00:00:04 4967MB | scene bounds: (-89.5046997 -0.226797104 -159.059036) -> (89.5046997 118.745636 159.059357)
00:00:04 4967MB | node update done in 0:00.00 (multithreaded)
00:00:04 4967MB | [gpu] updating 176 nodes ...
00:00:04 4967MB | [aov] parsing 2 output statements ...
00:00:04 4967MB | [aov] registered driver: "arv_display" (driver_arv)
00:00:04 4967MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:04 4967MB | [aov] * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:04 4967MB | [aov] done preparing 4 AOVs for 2 outputs to 1 driver (0 deep AOVs)
00:00:04 4967MB | starting render ...
00:00:04 4967MB | [gpu] building scene and compiling shaders ...
00:00:04 4967MB | [gpu] building scene and compiling shaders done in 0:00.000
00:00:08 5088MB | render done in 0:03.826
00:00:08 5088MB |
00:00:08 5088MB | -----------------------------------------------------------------------------------
00:00:08 5088MB | scene creation time 0:00.35 machine utilization (10.16%)
00:00:08 5088MB | plugin loading 0:00.12
00:00:08 5088MB | unaccounted 0:00.22
00:00:08 5088MB | frame time 0:03.83 machine utilization (31.91%)
00:00:08 5088MB | rendering 0:03.82
00:00:08 5088MB | output driver 0:00.04
00:00:08 5088MB | pixel rendering 0:03.78
00:00:08 5088MB | top session self-times by category
00:00:08 5088MB | worker waiting 0:05.97 (67.04%)
00:00:08 5088MB | accumulateBucketSamples 0:01.07 (12.11%)
00:00:08 5088MB | GPU iteration 0:00.70 ( 7.91%)
00:00:08 5088MB | fill_image 0:00.29 ( 3.27%)
00:00:08 5088MB | renderFrame 0:00.24 ( 2.73%)
00:00:08 5088MB | RenderBucket 0:00.20 ( 2.33%)
00:00:08 5088MB | top session self-times by node
00:00:08 5088MB | peak CPU memory used 5088.84MB
00:00:08 5088MB | at startup 1765.91MB
00:00:08 5088MB | plugins 17.68MB
00:00:08 5088MB | AOV samples 71.85MB
00:00:08 5088MB | output buffers 0.77MB
00:00:08 5088MB | node overhead 0.12MB
00:00:08 5088MB | message passing 0.01MB
00:00:08 5088MB | memory pools 12.05MB
00:00:08 5088MB | geometry 0.95MB
00:00:08 5088MB | polymesh 0.95MB
00:00:08 5088MB | strings 24.25MB
00:00:08 5088MB | texture cache 4.21MB
00:00:08 5088MB | profiler 0.05MB
00:00:08 5088MB | unaccounted 3191.00MB (note: interactive session)
00:00:08 5088MB | output buffers 640.00MB
00:00:08 5088MB | geometry 3.13MB
00:00:08 5088MB | polymesh 3.13MB
00:00:08 5088MB | texture cache 5.22MB
00:00:08 5088MB | unaccounted -648.35MB
00:00:08 5088MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
00:00:08 5088MB | camera 1048989 ( 0.02, 1.00) ( 1.60%) ( 1.00) ( 1)
00:00:08 5088MB | shadow 63010133 ( 1.39, 60.07) ( 96.19%) ( 0.30) ( 1)
00:00:08 5088MB | diffuse_reflect 1390063 ( 0.03, 1.33) ( 2.12%) ( 0.35) ( 1)
00:00:08 5088MB | specular_reflect 53987 ( 0.00, 0.05) ( 0.08%) ( 0.63) ( 1)
00:00:08 5088MB | total 65503172 ( 1.44, 62.44) (100.00%) ( 0.31) ( 1)
00:00:08 5088MB | by ray depth: 0 1 2 3 4 5
00:00:08 5088MB | total 95.6% 3.0% 1.0% 0.4% 0.0% 0.0%
00:00:08 5088MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:08 5088MB | lists 1 ( 0.0%) ( 0) ( 0.00, 0.00)
00:00:08 5088MB | polymeshes 144 (100.0%) ( 0) ( 1.10, 0.95)
00:00:08 5088MB | geometric elements ( min) ( avg.) ( max)
00:00:08 5088MB | polygons 20135 ( 30) ( 139.8) ( 8840)
00:00:08 5088MB | triangle tessellation ( min) ( avg.) ( max) (/ element) (% total)
00:00:08 5088MB | polymeshes 38602 ( 48) ( 268.1) ( 17680) ( 1.92) (100.00%)
00:00:08 5088MB | unique triangles 38602
00:00:08 5088MB | CPU memory use 0.95MB
00:00:08 5088MB | vertices 0.23MB
00:00:08 5088MB | vertex indices 0.11MB
00:00:08 5088MB | polygon base offsets 0.00MB
00:00:08 5088MB | polygon IDs 0.00MB
00:00:08 5088MB | triangulation 0.00MB
00:00:08 5088MB | packed normals 0.08MB
00:00:08 5088MB | normal indices 0.11MB
00:00:08 5088MB | uv coords 0.09MB
00:00:08 5088MB | uv coords idxs 0.12MB
00:00:08 5088MB | P reference (autobump) 0.10MB
00:00:08 5088MB | N reference (autobump) 0.03MB
00:00:08 5088MB | uniform indices 0.03MB
00:00:08 5088MB | userdata 0.01MB
00:00:08 5088MB | GPU memory use 3.13MB
00:00:08 5088MB | vertex indices 0.74MB
00:00:08 5088MB | normals 0.23MB
00:00:08 5088MB | normal indices 0.73MB
00:00:08 5088MB | uv coords 0.16MB
00:00:08 5088MB | uv coords idxs 0.74MB
00:00:08 5088MB | N reference (autobump) 0.10MB
00:00:08 5088MB | uniform indices 0.08MB
00:00:08 5088MB | other 0.02MB
00:00:08 5088MB | OpenImageIO Texture statistics
00:00:08 5088MB | Options: gray_to_rgb=1 flip_t=0 max_tile_channels=6
00:00:08 5088MB | Queries/batches :
00:00:08 5088MB | texture : 9084 queries in 9084 batches
00:00:08 5088MB | texture 3d : 0 queries in 0 batches
00:00:08 5088MB | shadow : 0 queries in 0 batches
00:00:08 5088MB | environment : 0 queries in 0 batches
00:00:08 5088MB | gettextureinfo : 0 queries
00:00:08 5088MB | Interpolations :
00:00:08 5088MB | closest : 4
00:00:08 5088MB | bilinear : 28052
00:00:08 5088MB | bicubic : 5289
00:00:08 5088MB | Average anisotropic probes : 1.89
00:00:08 5088MB | Max anisotropy in the wild : 85.6
00:00:08 5088MB |
00:00:08 5088MB | OpenImageIO ImageCache statistics (0000008FE414C040) ver 2.2.1
00:00:08 5088MB | Options: max_memory_MB=4096.0 max_open_files=1536 autotile=0
00:00:08 5088MB | autoscanline=1 automip=0 forcefloat=0 accept_untiled=1
00:00:08 5088MB | accept_unmipped=1 deduplicate=1 unassociatedalpha=0
00:00:08 5088MB | failure_retries=0
00:00:08 5088MB | Images : 4 unique
00:00:08 5088MB | ImageInputs : 4 created, 2 current, 2 peak
00:00:08 5088MB | Total pixel data size of all images referenced : 9.5 MB
00:00:08 5088MB | Total actual file size of all images referenced : 1.5 MB
00:00:08 5088MB | Pixel data read : 4.2 MB
00:00:08 5088MB | File I/O time : 1.0s (0.1s average per thread, for 13 threads)
00:00:08 5088MB | File open time only : 0.0s
00:00:08 5088MB | ImageInput mutex locking time : 0.0s
00:00:08 5088MB | Tiles: 252 created, 235 current, 235 peak
00:00:08 5088MB | total tile requests : 65757
00:00:08 5088MB | micro-cache misses : 1102 (1.67587%)
00:00:08 5088MB | main cache misses : 252 (0.383229%)
00:00:08 5088MB | redundant reads: 3 tiles, 72 KB
00:00:08 5088MB | Peak cache memory : 4.2 MB
00:00:08 5088MB | Image file statistics:
00:00:08 5088MB | opens tiles MB read --redundant-- I/O time res File
00:00:08 5088MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.jpg
00:00:08 5088MB | 2 1 83 0.6 0.0s 1200x 500x1.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Displacement.tx MIP-COUNT[47,22,10,3,0,0,0,0,0,0,1]
00:00:08 5088MB | BROKEN D:/Maya Projects/Practice/sourceimages/Dougnut Texture.jpg
00:00:08 5088MB | 4 1 152 3.6 ( 3 0.1) 1.0s 1200x 500x3.f16 D:/Maya Projects/Practice/sourceimages/Dougnut Texture.tx MIP-COUNT[93,38,10,3,2,1,1,1,1,1,1]
00:00:08 5088MB |
00:00:08 5088MB | Tot: 4 235 4.2 ( 3 0.1) 1.0s
00:00:08 5088MB | 2 were constant-valued in all pixels
00:00:08 5088MB | Broken or invalid files: 0
00:00:08 5088MB | number of warnings, warning type:
00:00:08 5088MB | 1: [disp] %s: padding is at least %.3gx smaller than it should be! given disp_padding: %.9g, recommended: %.9g
00:00:08 5088MB | performance warnings:
00:00:08 5088MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:08 5088MB | [color_manager] rendering color space is "ACEScg"
00:00:08 5088MB |
00:00:08 5088MB | rendering image at 4096 x 4096, -1 AA samples
00:00:08 5088MB | AA samples max 0
00:00:08 5088MB | AA adaptive threshold 0.015
00:00:08 5088MB | AA sample clamp <disabled>
00:00:08 5088MB | diffuse samples 1 / depth 3
00:00:08 5088MB | specular samples 2 / depth 2
00:00:08 5088MB | transmission samples 2 / depth 9
00:00:08 5088MB | volume indirect <disabled by depth>
00:00:08 5088MB | total depth 10
00:00:08 5088MB | bssrdf samples 2
00:00:08 5088MB | transparency depth 11
00:00:08 5088MB | node initialization done in 0:00.00 (multithreaded)
00:00:08 5088MB | updating 176 nodes ...
00:00:08 5088MB | node update done in 0:00.00 (multithreaded)
00:00:08 5088MB | [aov] parsing 2 output statements ...
00:00:08 5088MB | [aov] registered driver: "arv_display" (driver_arv)
00:00:08 5088MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:08 5088MB | [aov] * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:08 5088MB | [aov] done preparing 4 AOVs for 2 outputs to 1 driver (0 deep AOVs)
00:00:08 5088MB | starting render ...
00:00:08 5088MB | [gpu] building scene and compiling shaders ...
00:00:08 5088MB | [gpu] building scene and compiling shaders done in 0:00.000
00:00:11 5082MB ERROR | [gpu] an error happened during rendering. OptiX error is: Unknown error (Details: Function "_rtContextLaunch2D" caught exception: Encountered a CUDA error: cudaDriver().CuEventSynchronize( m_event ) returned (702): Launch timeout, file: <internal>, line: 0)
00:00:11 5082MB | render done
