Announcements
arnold does not render applied material
carlcox62
carlcox62
i assigned an aistandardsurface material to the sphere. rendersettings all see like on screenshot. under the textures tab in rendersettings i dissabled convert textures to tx for better performance, bucketsize is set to 16. after loading the same scene first time, i wasnt able to see material, i dont know why. the skydomelight's visibility is set to zero because i so can concentrate on rendering more. saved ui threads is set to 3. anyway, it takes a long time to ipr current perspectiveview/frame. viewport view is okay.
carlcox62
okay. after reopen file, restarting maya the arnoldrenderview is okay now.
i have a second question. i cant see the menu, i dont know how it named, in the hypershade for view, edit and so on.
how do i make it visible?? even if i choose show all uielements i cannot see.
hamsterHamster
Because of this Alpha chan display switch:
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
carlcox62
hamster how can i make this menu for edit and view and so on make appear in the hypershade?? this menu on very top of the window. and whats the name of it by the way?
hamsterHamster
Menubar..
See Prefs, enable inPanels
,,,_°(O__O)°_,,,
carlcox62
thanks so much!
Type a product name
