Arnold displacement map artifacts, seam
Message 1 of 1
I've some displacement artifacts using Arnold Renderer. The ZBrush Sculpt doesn't have that artifact. Tried to adjust the UVs, changing ZBrush displacement map export settings and tweaking the smoothing UV settings. However, no matter what I do; the problem still remain. (linear UV smoothing has the best result, but if zoom in; there're still artifacts)
The artifact is not happened in the UV border, I've already moved the seam line behind.
Any help would be appreciated, thanks! Attached is the .ma file and displacement .exr
ZBrush_Sculpt.pngDisplacement_Seam_01.jpgDisplacement_Seam_02_Linear.jpgSubD_Settings.pngUV.pngUV_Overlay.png
Replies (0)
