Ai Toon texturing, Mixing with Ai Standard
samuel.nickson
samuel.nickson
I am quite new to the AiToon and I don't quite understand how to tackle my problem, considering I've already read the manual. I have a character with a base colour texture file that textures the entire character. I want to also use the AiToon to give it that 2D contour effect. Yes I already know about changing the render settings to contour. I don't want to over complicate the texturing process with ramps or have lots of textures for one model.
Do I need to add some kind of mixture node to allow the AiToon node to be linked to the AiStandard node? Or am I over complicating it. Please let me know what you all think and thank you very much.
faline.custodio.da.silva
@samuel.nickson
Thanks for posting!
We suggest rendering the edge separately and compositing them together. This page could be helpful to you: https://docs.arnoldrenderer.com/pages/viewpage.action?pageId=71008401#AOVs%28Toon%29-RenderingEdgesS...
Using Toon means you need to use the Contour filter, so you'll be rendering a combination of the Standard Surface with the Contour filter and mixing them. Standard Surface returns a closure, not a color value, so you cannot plug Standard Surface into Toon.
In this example, we used a Passthrough node to force MtoA to convert the Mix shader to mix_shader instead of mix_rgba:
I hope that helps!
Faline Custodio Da Silva
