Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Accurate Window Reflections
1 REPLY 1
461 Views, 1 Reply
Hi there everyone,
I am trying to recreate the effect you see in windows where the light bounces back between the double-glazed window and creates this effect where the light seems to fade away the further it gets away from the light source.
I have tried playing around with the settings on the glass but I can't seem to get the effect going. When I try to tweak the values all the reflections of light fade simultaneously.
(Arnold Renderer)
Thank you for your time
Labels (1)
1 REPLY 1
hamsterHamster
Can't you just apply less reflective shader to the outer glass. If you need "the infinite reflections", then make more glass planes with even less reflectivity, and, perhaps, leave just specular output.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Technology Administrators
