Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
2023.3 : the legacy renderView disappear once ArnoldPlugin is loaded
4 REPLIES 4
visu
263 Views, 4 Replies
Arnold plugin  loaded the legacy renderView is no more available, the shortcut open ArnoldView, and window rendering editor access as well.
4 REPLIES 4
Stephen.Blair
in reply to: visu
Right. As of MtoA 5.2.0 (Aug 2022), the Arnold Render View replaces the Maya Render View for Arnold rendering.
  • Arnold Render View by Default: The Maya Render View has been replaced with the Arnold Render View for Arnold Renders and IPR, except for Render Sequence (MTOA-1008)
// Stephen Blair
// Arnold Renderer Support
visu
in reply to: Stephen.Blair
This answer is from Autodesk ?
This means a renderer without its specific RenderView plugin is no longer renderable.
thats the case for Iray, not RedShift.
Stephen.Blair
in reply to: visu
Change the current renderer, no? Then you get the render view that's available for that other renderer.
// Stephen Blair
visu
in reply to: visu
oh i see.
the renderView is no more a generic window but a call to the defaultRenderer from the Globals.
it means you set the renderer ( whatever the favorite in globals ) and open RenderView afterward.
you are right !  it is a design workflow change to my habit.
Technology Administrators
