Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Write to command response in MEL
3 REPLIES 3
1835 Views, 3 Replies
Is there a way to write to the Command Response (1 line console window) . I'm not after coloured (warning) text - but that would be nice. Just a the Melonic equivalient to :
# writes to Maya Command Response
import sys
cheese = "Gwen Stefani"
sys.stdout.write(cheese)
Cheers.
3 REPLIES 3
rflannery
To write a plain message, use "print":
$s="Hello There";
print ($s + "\n");
To write a colored warning message, use "warning":
$t="Oh, no!";
warning $t;
There is also a colored error message.  Note that your script will stop executing if it encounters the "error" command:
$u = "Something went really wrong!";
error $u;
print "I will never reach this line of code\n";
Note that with "print", you generally want to include a newline, "\n", at the end of your message.  With "warning" and "error" you don't have to include the newline.
in reply to: rflannery
Doh! And there was I looking for a clever solution....
I find it odd (and inconsistant) that print in MEL will write to the Command Response, but Python won't. 😐
rflannery
Heh, I never noticed that before.  I knew that you could use "cmds.warning" and "cmds.error" in Python, and those show output in the desired location.  But sure enough, Python's "print" statement only shows the output in the Script Editor.  (And there is no "cmds.print".)
