Voronoi polygons?
Voronoi polygons?
hintzjt7
Message 1 of 9
Voronoi polygons?
hintzjt7
Is there a way to generate voronoi polygons on a 3d mesh.
Replies (8)
Message 2 of 9
cheng_xi_li
Autodesk Support
Autodesk Support
If you want to draw the mesh after voronoi polygon is generated, it is possible.
There is a footPrintNode sample in our devkit, it shows how to draw mesh in the Maya.
Message 3 of 9
hintzjt7
I want to make voronoi polygons on top of a 3d mesh. If so, how?
Message 4 of 9
cheng_xi_li
Autodesk Support
Autodesk Support
Hi hintzjt7,
I think you use MFnMesh to modify the the 3dmesh you want after you have generated voronoi polygons.
I know a third party library called voro++ can be used for generating the Voronoi cells.
Yours,
Li
Message 5 of 9
hintzjt7
Message 6 of 9
cheng_xi_li
Autodesk Support
Autodesk Support
I think they are voronoi polygons on a 3d mesh.
You can use MFnMesh to get the entire mesh data of the head or use MSelectionList and MItMeshPolygon to get user desired polygons. With these data, you can generate a voronoi surface with certain library or algorithm. At last, draw them as your custom node like the sample in the Maya devkit.
Message 7 of 9
hintzjt7
What about generating smaller and larger voronoi polygons on the same mesh? Can I use paint maps for that?
Message 8 of 9
cheng_xi_li
Autodesk Support
Autodesk Support
What kind of tool(mel, api or Maya itself) are you trying to create the voronoi mesh? I don't think there is a tool for generating voronoi directly in Maya.
Message 9 of 9
hintzjt7
I want to create a Maya tool for generating voronoi polygons.
