Update Expression automatically when value changes in another attribute
Message 1 of 8
Hi All,
What I'd like to do is control the translation limits for a control based on the twist attribute of a second control. I've created an expression within the Expression Editor and it works once when I hit Edit. However, I want it to evaluate every time the twist value changes. I'm pretty sure I've seen it done before but I'm drawing a blank on how to do it.
float $twistValue = `getAttr("torso_CTL.twist")`;
if ($twistValue < -10)
	transformLimits -tz 0 200 -etz 1 1 CTRL_throttleHandle;
else if ($twistValue >= -10 || $twistValue <= 10)
	transformLimits -tz 50 250 -etz 1 1 CTRL_throttleHandle;
else
	transformLimits -tz 100 300 -etz 1 1 CTRL_throttleHandle;
Replies (7)
Message 2 of 8
lee.dunham
Expressions are different to scripts, and you usually try to avoid using things like getAttr and setAttr.
Instead, you access the attribute directly, and I think it will provide the behaviour you are looking for.
if torso_CTL.twist < -10 {
Message 3 of 8
Thanks @lee.dunham
Accessing the attribute directly does help with setting up the expression, but it still doesn't apply the changes automatically when I change the value of torso_CTL.twist. I thought perhaps there was a way to do this with expressions, but I'm starting to consider that there isn't.
Message 4 of 8
lee.dunham
I don't have access to Maya atm, but you could look at a scriptJob tied to attributeChanged instead?
Message 5 of 8
Hi @lee.dunham
I've been on a big project with a looming deadline so I haven't had a chance to try your suggestion yet but I'll let you know how it goes when I do.
Thanks!
Message 6 of 8
olarn
Message 7 of 8
@olarn I ended up just using the node editor to get the results that I wanted. Since I was dealing with 3 scenarios rather than a simple if / else situation, I had to get creative with the nodes.
Message 8 of 8
olarn
Nice.
I'd like to interject for some more that implement as nodes has one more hidden benefits -- free parallelization.
