Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Unfold Along U Hotkey/MEL command doesn't exist
3 REPLIES 3
dovhaliuk.stanislav
280 Views, 3 Replies
Hello. I tried to add the "Unfold Along U" command to the hot button in Hotkeyeditor and It's not in the hotkey editor.
MEL script
unfold -i 5000 -ss 0.001 -gb 0 -gmb 0.5 -pub 0 -ps 0 -oa 2 -us off
unfolds the entire mesh, but I only need the selected shell.
I tried to write my own scripts - nothing happened. help me please
In the Script Editor and Echo All Command when I press Unfold Along U button [not hotkey] Maya write:
unfold -i 5000 -ss 0.001 -gb 0 -gmb 0.5 -pub 0 -ps 0 -oa 2 -us off lod00_tst:wersdasd.map[8:9] lod00_tst:wersdasd.map[13] lod00_tst:wersdasd.map[15] lod00_tst:wersdasd.map[51:52] lod00_tst:wersdasd.map[55:57] ;
I tried to combine
and
$shellUVs = `ls -sl`;
print $shellUVs;
and in some reasone Maya write another values
lod00_tst:wersdasd.f[7]
lod00_tst:wersdasd.f[9:10]
lod00_tst:wersdasd.f[19]
lod00_tst:wersdasd.f[39:40]
💁‍:male_sign:💁‍:male_sign:💁‍:male_sign:💁‍:male_sign:💁‍:male_sign:
Labels (3)
3 REPLIES 3
Hi!
Thats because when you use UV Shell selection, you actually select faces, not UV's. But the unfold command only takes UVs as positional input. When you hit the unfold along U button from the menu, Maya automatically converts your selections to UV's, if you do it via code, you have to add that line yourself. This should work for what you want to do:
string $slUVs[] =`polyListComponentConversion -tuv`;
unfold -i 5000 -ss 0.001 -gb 0 -gmb 0.5 -pub 0 -ps 0 -oa 2 -us off $slUVs;
I hope it helps!
Works. Thank you !! 🦾🦾
Tell me, what should I read to better understand mEl? Please.
Hi!
The official documentation is always helpful when you want to work with MEL, it lists most of the stable commands that can be used in MEL.
https://help.autodesk.com/cloudhelp/2024/ENU/Maya-Tech-Docs/Commands/
Sadly there aren't many good written tutorials on MEL since it is quite a niche language.
