Hi there,
I do have two groups: "BG" and "HT"
I'd like to make set driven key via mel that makes like that:
when HT's visibility is on - then the BG's is off
i dont know where shell i put the driven flags and values...
setDrivenKeyframe -cd HT -at HT.visibility -dv 1 -at BG.visibility -v 0;
Solved by mcw0. Go to Solution.
Is there a reason you want to use a setDrivenKey for this relationship? You can use a reverse node to do the same thing. Less work...in my opinion. 🙂
