Hi I have a problem with the rowColumnLayout. As you can see in the first image (attached below) I would like to have the 'COLOR' title centered, however I don't want it to be part of the first rowColumnLayout. Please refer to the second mockup image of how I would like it to be.
Any help please? Thanks in advance. Code attached below.
if cmds.window('CRV_Generator', exists = True):
cmds.deleteUI('CRV_Generator')
cmds.window('CRV_Generator')
cmds.rowColumnLayout(nc = 1)
cmds.separator(style='none', h=5)
cmds.text(label='CREATE SHAPES')
cmds.rowColumnLayout(nc = 2)
cmds.button(label = 'Circle', w = 150, c = 'createCircle()')
cmds.button(label = 'Square', w = 150, c = 'createSquare()')
cmds.button(label = 'Box', w = 150, c = 'createBox()')
cmds.button(label = 'Pyramid', w = 150, c = 'createPyramid()')
cmds.button(label = 'Triangle', w = 150, c = 'createTriangle()')
cmds.button(label = 'Info', w = 150, c = 'createInfo()')
cmds.button(label = 'Double Arrow', w = 150, c = 'createDoubleArrow()')
cmds.button(label = 'Arrow', w = 150, c = 'createArrow()')
cmds.button(label = 'Directional', w = 150, c = 'createDirectional()')
cmds.button(label = 'Platonic', w = 150, c = 'createPlatonic()')
cmds.text(label='COLOR')
cmds.button(label = 'Red', w = 150, c = 'changeColor(13)')
cmds.button(label = 'Blue', w = 150, c = 'changeColor(6)')
cmds.button(label = 'Yellow', w = 150, c = 'changeColor(17)')
cmds.button(label = 'Green', w = 150, c = 'changeColor(14)')
cmds.button(label = 'Pink', w = 150, c = 'changeColor(9)')
cmds.button(label = 'Light Blue', w = 150, c = 'changeColor(18)')
cmds.showWindow()
Solved by rajasekaransurjen. Go to Solution.
Try this.....
import maya.cmds as cmds if cmds.window('CRV_Generator', exists = True): cmds.deleteUI('CRV_Generator') cmds.window('CRV_Generator') cmds.rowColumnLayout(nc = 1) cmds.separator(style='none', h=5) cmds.text(label='CREATE SHAPES') cmds.separator(style='none', h=5) cmds.rowColumnLayout(nc = 2, columnWidth=[(1, 150), (2, 150)]) cmds.button(label = 'Circle', w = 150, c = 'createCircle()') cmds.button(label = 'Square', w = 150, c = 'createSquare()') cmds.button(label = 'Box', w = 150, c = 'createBox()') cmds.button(label = 'Pyramid', w = 150, c = 'createPyramid()') cmds.button(label = 'Triangle', w = 150, c = 'createTriangle()') cmds.button(label = 'Info', w = 150, c = 'createInfo()') cmds.button(label = 'Double Arrow', w = 150, c = 'createDoubleArrow()') cmds.button(label = 'Arrow', w = 150, c = 'createArrow()') cmds.button(label = 'Directional', w = 150, c = 'createDirectional()') cmds.button(label = 'Platonic', w = 150, c = 'createPlatonic()') cmds.columnLayout(w=300) cmds.separator(style='none', h=5, w=300) cmds.text(label='COLOR', w=300) cmds.separator(style='none',w=300, h=5) cmds.rowColumnLayout(nc = 2, columnWidth=[(1, 150), (2, 150)]) cmds.button(label = 'Red', w = 150, c = 'changeColor(13)') cmds.button(label = 'Blue', w = 150, c = 'changeColor(6)') cmds.button(label = 'Yellow', w = 150, c = 'changeColor(17)') cmds.button(label = 'Green', w = 150, c = 'changeColor(14)') cmds.button(label = 'Pink', w = 150, c = 'changeColor(9)') cmds.button(label = 'Light Blue', w = 150, c = 'changeColor(18)') cmds.showWindow()
