Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Ramp attribute crash in compound attribute
2 REPLIES 2
peter.kalmar
346 Views, 2 Replies
Hey,
I am making a C++ plugin and I have a weird crash when using MRampAttributes.
I have an MPxNode, which has a child array of compound attributes.
When I try to add one or more ramp attributes as a child to this compound, Maya crashes when loading the plugin without providing a stack-trace in the Output window.
So the desired structure would be:
node.childCompoundArray[0].rampAttribute
Sometimes the plugin works with one ramp attribute added, but crashes when I add another one next to the first.
(node.childCompoundArray[0].rampAttributeB)
Any ideas why this may happen?
Does Maya prohibit using ramp attributes as child attributes / in an array?
Or can this be the fault of having multiple ramp attributes next to each other?
I have not found anything in the official documentation on this matter.
I am using the Maya 2019 API.
Thanks in advance,
Peter
Labels (2)
2 REPLIES 2
jmreinhart
in reply to: peter.kalmar
Could you please post a code sample that reproduces your issue?
peter.kalmar
in reply to: jmreinhart
Sure!
// A static function that is called by the node's initializer.
// We pass the references to the static attribute MObjects.
// This function is used in several nodes to add the commonly used attributes.
// Unrelated code was omitted.
// All other attributes are working correctly (numeric, typed, compound, matrix etc.)
void SamplerUtils::createCommonAttributes(
	MObject& sModifiers,
	MObject& sModifierEnabled,
	MObject& sModifierScaleRamp,
	MObject& sModifierScaleFalloff,
	MObject& sModifierDensityRamp,
	MObject& sModifierDensityFalloff,
	MStatus status;
	MFnNumericAttribute nAttr;
	MFnCompoundAttribute cAttr;
	sModifierEnabled = nAttr.create("modifierEnabled", "moden", MFnNumericData::kBoolean, 0, &status);
	CHECK_MSTATUS(status);
	nAttr.setDefault(true);
	sModifierScaleFalloff = nAttr.create("modifierScaleFalloff", "modscf", MFnNumericData::kFloat, 10.0f, &status);
	nAttr.setMin(0.0f);
	nAttr.setDefault(10.0f);
	nAttr.setSoftMax(30.0f);
	sModifierDensityFalloff = nAttr.create("modifierDensityFalloff", "moddef", MFnNumericData::kFloat, 10.0f, &status);
	nAttr.setMin(0.0f);
	sModifierScaleRamp = MRampAttribute::createCurveRamp("modifierScaleRamp", "modscr", &status);
	sModifierDensityRamp = MRampAttribute::createCurveRamp("modifierDensityRamp", "modder", &status);
	sModifiers = cAttr.create("modifiers", "mod", &status);
	CHECK_MSTATUS(cAttr.addChild(sModifierEnabled));
    // CRASH!
	// CHECK_MSTATUS(cAttr.addChild(sModifierScaleRamp));
	CHECK_MSTATUS(cAttr.addChild(sModifierScaleFalloff));
    // CRASH!
	// CHECK_MSTATUS(cAttr.addChild(sModifierDensityRamp));
	CHECK_MSTATUS(cAttr.setArray(true));
	CHECK_MSTATUS(MPxNode::addAttribute(sModifiers));
 If I add the ramp attributes to the node itself, and not as a child in the compound it works - sometimes. Other times it still crashes Maya.
Péter
