@cheng_xi_li
I can't get my 2025 Qt plugin to load debug version, `Unable to dynamically load`, which suggests it can't get to Qt .dll's, correct?
Release version works fine. Is there part of the new recipe I'm missing? I've got a nasty bug and would love to attach and debug.
I remember a note about Qt debug versions from 2022.
# CMAKE for 2025
add_compile_definitions(QT_DISABLE_DEPRECATED_UP_TO=0x050F00)
set( libs Core Widgets Gui )
find_qt( "${libs}" )
Debug version works in 2023/2024.
#CMAKE 2023/2024
set(Qt5Core_VERSION_MAJOR 5)
set(Qt5Core_VERSION_MINOR 15)
elseif(CMAKE_SYSTEM_NAME STREQUAL "Windows")
set(QT_MOC_EXECUTABLE $ENV{DEVKIT_LOCATION}/devkit/bin/moc.exe)
set(Qt5::Widgets_PATH $ENV{DEVKIT_LOCATION}/lib/Qt5Widgets.lib)
set(Qt5::Core_PATH $ENV{DEVKIT_LOCATION}/lib/Qt5Core.lib)
set(Qt5::Gui_PATH $ENV{DEVKIT_LOCATION}/lib/Qt5Gui.lib)
endif()
# Configure Qt moc
add_executable(Qt5::moc IMPORTED)
set_target_properties(Qt5::moc PROPERTIES IMPORTED_LOCATION ${QT_MOC_EXECUTABLE})
list(APPEND CMAKE_AUTOMOC_MACRO_NAMES "MOUSEBUTTONEVENT_H")
set(CMAKE_AUTOMOC TRUE)
Zach
