Hi!
I'm trying to prevent the "mental ray not available dialog" from showing up in Maya in every subsequent file opening.
This is part of a process where preferences are constantly going to be different (each user using their own preferences).
I have tried starting Maya with the following env var set as True : MAYA_IGNORE_DIALOGS; but this doesn't seem to work in my case.
In addition, I don't have access to the import/open file part of that procedure, so using the prompt=False flag in the cmds.file() command is not an option.
I have tried to set that flag as False before the execution of the procedure, but this doesn't work either.
Is there any way I can reliably prevent Maya from showing up that dialog every time?
Preferably a way that can be set in the environment itself, or if not possible, right after Maya starts and before running anything else.
Thanks in advance for the help!
Cheers
