Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
preserve uvs
4 REPLIES 4
stuzzz
896 Views, 4 Replies
preserve uvs
hi,
Is there any function of snippets for preserving the UVs while translating points?
Thanks.
4 REPLIES 4
osidedan
in reply to: stuzzz
hello!
If you're using the xform command to move verticies, there is a preseveUV flag.
for example (in python):
# Moves a selected vertex to the world origin while preserving UV space
import maya.cmds as cmds
sel = cmds.ls(sl=True)[0]
cmds.xform(sel, t=(0,0,0), preserveUV=True)
Hope that helps!
stuzzz
in reply to: osidedan
Interesting. I did not have a look at the Maya commands since I use the c++ api.
I'd like to avoid using xform.
Do you know if there is a equivalent api function for this purpose?
osidedan
in reply to: stuzzz
Oh if you're doing api/plug-in stuff, then that is definitely outside of my knowledge base. Someone else will need to chime in on that. I hope you get it figured out though!
The-Digital-Shaman
in reply to: stuzzz
What's wrong about xform?
