Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Plugin not found
4 REPLIES 4
MikeSSSS
2234 Views, 4 Replies
Plugin not found
MikeSSSS
I have a perhaps 'classic' problem with having trouble getting a .mll file running on another persons machine using the same version of Maya 2020.
I want them to be able to use just the .mll file. I'm assuming I would need to also package up other .dll dependencies needed in the same folder, but am I missing anything else? (There are no .mel scripts otherwise used, it's just a pure C++ plugin).
Is it a absolute or relative path issue in my linker settings? Any suggestions would be helpful!
Plugin not found
4 REPLIES 4
mspeer
in reply to: MikeSSSS
mspeer
Hi!
"...using the same version of Maya 2020."
- Based on the screenshot you are using Maya 2018. A plug-in version for Maya 2020 will not work with Maya 2018.
Hi!
MikeSSSS
in reply to: mspeer
MikeSSSS
Ah noted! I tried on both 2018 and 2020.
Same message appears about the plugin not being found.
mspeer
mspeer
Hi!
i recommend to check the following article which covers the most common causes (of course you have to adapt it to your plug-in, but incorrect paths, missing environment variables, PATH variables or dll files can cause this):
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-The...
Hi!
MikeSSSS
in reply to: mspeer
MikeSSSS
Thank you for your help.
The solution I found was that my PATH variable needed to know where the plugin was.
Here's how I debugged it so others can learn:
1. I ran dependency walker (a windows program) on my .mll file to see what .dll's it needed.
2. I then made sure a few of the .dll's (including standard ones like foundation.dll, openmayaui.dll, etc.) were in the same directory. Dependency walker displays a little yellow box or otherwise some warning if they are missing.
3. I then eventually found that Maya 2020 looks on the PATH variable for various .dll files that your plugin might need. So I edited PATH to include where my .mll plugin was.
There are probably other paths that need to be set like MAYA_PATH or something similar, and I would probably be able to set those through an installer with my plugin, but the above should otherwise work.
