Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
override ApplicationPlugins directory
5 REPLIES 5
spark6C3TN
1246 Views, 5 Replies
I am looking for an environment variable, or a method that I can override ApplicationPlugins directory, which is a default location of installing maya bonustools.
Is there a clean way to re-direct the location instead of individually setting plugins, pythonpath, and script paths?
Labels (2)
5 REPLIES 5
g2m.agent
in reply to: spark6C3TN
spark6C3TN
in reply to: g2m.agent
Thank you for the link, I am setting Maya bonus tools to a shared location, and it includes various plugins and scripts and I hope there is a better way than setting multiple MAYA paths.
I tried setting MAYA_PACKAGE_PATH to the directory having PackageContents.xml file, but it doesn't change anything. Is there a success story with the environment variable?
https://apps.autodesk.com/en/Detail/Index?id=8115150172702393827
spark6C3TN
Maya 2022 help for the file path variables gave me the answer. Thank you.
vonbehr
How did you solve it?
I did set the MAYA_PACKAGE_PATH variable to the folder with the PackageContents.xml but the Bonus Tools are not loaded.
Is this env variable even available in Maya versions before 2020?
KernAttila_Zag
You need to point to the folder above, containing the BonusTools folder
