I have a problem with a script migNormalTools, it is a script for tweaking vertex normals in Maya
There is not any errors, looks like script is implemented, but nothing is happened, it should add new menu bar (somewhere after Help bar) called a Normal tools.
this is a link where i downloaded ithttps://mega.nz/#!M4J1VART!vdXvoGTXhKTIClsU6klThX1DFtMOtvRRXhrBqzjYlA0
Solved by ilyaz14. Go to Solution.
Solved by write migNormalTools () in command line and then implement the script
