ok... So let's say i have a Rig.
I need to find a specific parent within that rig.
Let's say "L_Arm" has a Parent from "Locator1" with the name "L_Arm_ParentConstraint1"
How do i find and delete that constraint without deleting any other constraints that are within the rig.
I tried to combine names like
$selRig = `ls -sl`; (L_Arm)
select $selRig+"_parentConstraint1"; which i hoped would result in (L_Arm_parentConstraint1)
but apparently you cant use + to add names onto strings.
Maybe this would be easier if the parent had a specific name.
Instead of L_Arm_ParentConstraint1 ... DelThisParentConstraint1.
so...
How do i find and delete that specific parent using MEL?
Can i attach a name to a string and use the select command to achieve this?
Can i create a parent with a specific name?
I know you can create a locator with
spaceLocator -name "NameHere";
so...
Solved by mcw0. Go to Solution.
Firstly, you're not actually talking about a parent. You're talking about a parentConstraint. So let's get the terminology correct. Any script that is hardcoding names is not a good idea. You should use node types to find the parentConstraint. Also, the "ls" command returns an array. So that prevents you from appending a string.
string $sel[] = `ls -sl`;
string $newName = ($sel[0]+"_appendString");
To find a parentConstraint, you can use "listConnections".
string $results[] = `listConnections -s 1 -d 0 -type "parentConstraint" "selectedNode"`;
*** Replace "selectedNode" with your node ***
so all i had to do was use an array [x]... i feel dumb.
Well thanks.
now i have a different issue tho. The Controls for the char have a Prefix. The parentConstraint doesn't.
select -r ($selection[0] +"_parentConstraint1");
Gives me an error "no object matches name "somePrefix:L_hand_parentConstraint1""
need something like this.
select -r (stringRemovePrefix (PREFIX_HERE, $selection[0]) +"_parentConstraint1");
any ideas?
Well thanks.
any ideas?
Yes. As I stated before, hardcoding names in a script is not good practice. You can never be assured of a naming convention. So use my suggestion of listConnections and specifying a type.
im unfamiliar with that method.
Hardcoded names should not be an issue since it's my own custom project. The names are consistent throughout.
Select a node that has a parentConstraint on it.
string $parentConstraint[] = `listConnections -s 1 -d 0 -type "parentConstraint" $sel[0]`;
select -r $parentConstraint[0];
