Why does polyDisc return polyDisc -sides 3 -subdivisionMode 4 -subdivisions 3 -radius 1; instead of the Object Name ?
This is very annoying. Most poly creation commands results in the object name instead of cmd name.
Like this
polyCube -ch on -o on -w 1.362547 -h 1.362547 -d 1.362547 -cuv 4 ;
// Result: pCube1 polyCube1 //
Like this
I am trying to create a mel script using polydisc but it's going to be tougher because this polyDisc command, doesn't undo like zewt says and worse the -n flag for name doesnt work on it, one has to select the polyDisc and rename it (3 steps). Why are they putting out Maya with these flawed functions?
@Anonymous when you run polyDisc command, it auto selects the transform node. so it can be optimized into 2 steps.
polyDisc -r 1 -s 4 -sd 1;
string $polyDisc = `rename "pDiscMesh"`;
its a bummer that undo doesn't work with these commands which makes undo system broken
