Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
[MEL] Change attributes via script for Camera/Imageplane
4 REPLIES 4
niktr96
794 Views, 4 Replies
niktr96
ok so currently i have this
string $cam[] = `ls -sl`;
string $camR[] = listRelatives($cam[0]);
string $camC[] = listConnections($camR[0]);
if (getAttr($camC[0]+".depth" == 2)){
setAttr $camC[0]+".depth" = 10000;
setAttr $camC[0]+".alpha" = 0.5;
setAttr $camR[0]+".nearClipPlane" = 1;
which should give you a rough idea of what im trying to do.
it needs to be dynamic so it works with any camera, any name and multiple connections/relations attached to that camera. Basically, if it's a camera that has an imagePlane attached, this script must edit all attributes.
Any suggestions?
Any suggestions?
Tags (3)
Labels (3)
4 REPLIES 4
Kahylan
in reply to: niktr96
Kahylan
Hi!
If I understand you correctly, you want to change attributes on all cameras that have connected image planes.
For that you just need to understand some fundamentals about hierarchy and object types.
The shape nodes of Cameras have type "camera" which has its own tag in the ls command.
The shapeNodes of imagePlanes are type "imagePlane" which can be queried during listRelatives. Also imageplanes are children of the shape node of the Camera.
//get all Cameras
string $cams[] = `ls -cameras`;
// loop through cameras
for ($c in $cams){
    //get all image Planes parented to camera
    string $planes[] = `listRelatives -ad -typ "imagePlane" $c`;
    //check if there are image planes
    if (size($planes) !=  0){
        //setAttr on cam
        setAttr ($c + ".nearClipPlane") 1;
        //setAttr for all imagePlanes
        for($p in $planes){
            setAttr ($p +".depth") 10000;
            setAttr ($p +".alphaGain") 0.5;
This worked for me. But it just made my plane disappear because 10000 is an extremely high depth value.
I hope this helps!
Hi!
//get all Cameras
for ($c in $cams){
        //setAttr on cam
        for($p in $planes){
I hope this helps!
niktr96
niktr96
Thank you for the reply.
your code does work, but i need it to work for a specific Selection of cameras.
Which is why i used
string $cams[] = `ls -sl`;
could you please modify your code for this scenario?
Which is why i used
Kahylan
Kahylan
Ah ok, I understand.
Just exchange the declaration of $cams with:
string $cams[] = `ls -sl -dag -lf -cameras`;
Depending on your maya version you'll have to restart your maya before executing the modified script, because the old variable $cams will still be stored in memory.
I hope this helps!
I hope this helps!
niktr96
niktr96
thanks a lot 🙂
and yea i wish there was a way to clear script cache so variables don't get permanently saved into the session.
I've had so many issues because of that "feature"
thanks a lot 🙂
