Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Mac Maya 2024 subprocess.Popen not working
0 REPLIES 0
Message 1 of 1
simonbenanderson
347 Views, 0 Replies
Hi Community and Autodesk Devs,
I am currently trying to use mayabatch to call a mel file which will perform a bunch of python tasks.
I am on an M1 Silicon Mac, using OS Ventura
To launch mayabatch I am using python's subprocess.Popen command. Sadly it looks like it is not working.
What currently happens, mayabatch launches and then completes, it does not seem to register the -script or the -command. I have tried it with both mayabatch and maya -batch, and get the same results.
I have also tried with run and check_call, in every scenario no error appears, it just doesn't seem to evaluate the extra attributes.
I have also tried different formatting of the input array, to no avail.
If I run the command in a OSX Terminal it evaluates correctly.
The following is the array of data I pass in to popen
['/Applications/Autodesk/maya2024/Maya.app/Contents/bin/maya -batch', '-script', '/var/folders/z2/jc4yqlqn5hz06r32v625tdkr0000gn/T/tmpk32i15tp.mel']
This is the concatinated version I run in Terminal.
/Applications/Autodesk/maya2024/Maya.app/Contents/bin/maya -batch -script /var/folders/z2/jc4yqlqn5hz06r32v625tdkr0000gn/T/tmpk32i15tp.mel
Any help on getting a command to register correctly on Mac using open in Maya would be greatly appreciated.
Simon
Labels (4)
0 REPLIES 0
