in Maya 2017 I'm having a problem running any type of scripts. every time I enter to run the script doesn't work instead I keep getting this "line 1.5: Syntax error // " all the time. I tried resetting to default settings and this didn't work soi don't know what am I doing wrong.
Solved by rflannery. Go to Solution.
If you are using the Script Editor, make sure the tab is the correct language. In other words, make sure you are not trying to run a Python script in a MEL tab or vice versa.
