Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
I keep getting # Error:invalid syntax # can someone find the error
1 REPLY 1
1065 Views, 1 Reply
# dfMakeTx
# Concept & Design: Derek Flood, Python scripting: ShanShan He 2017
# See http://docs.sharktacos.com/texture/abcTex.html for detailed description
# Usage: To call the script, copy the text here and paste it into the
# Maya Script Editor in a Python tab. Hit "play" in the Script Editor to launch the GUI.
# You can also make a shelf button for it by selecting the text in the Python tab
# and MMB-draging it into the Maya shelf.
import maya.cmds as mc
import os, sys
if mc.window('TransferTex', ex = True):
mc.deleteUI ('TransferTex')
window = mc.window( "TransferTex",widthHeight=(250,155))
mainLayout = mc.columnLayout( adjustableColumn=True )
routeLayout11 = mc.rowLayout(nc = 4, w = 390, cw4 = (5,90,28,5), p = mainLayout )
routeRow44 = mc.text(label = '', p = routeLayout11)
routeRow11 = mc.button( label='Select Source',command = 'sSource()' ,p = routeLayout11 )
routeRow22 = mc.textScrollList( 'sourcegroup', numberOfRows=6, allowMultiSelection=True, a = [], w = 150, h = 22, p = routeLayout11,
showIndexedItem=1 )
mc.separator( height=40, w = 430, style='out', p = mainLayout )
routeLayout1 = mc.rowLayout(nc = 4, w = 390, cw4 = (5,90,28,5), p = mainLayout )
routeRow4 = mc.text(label = '', p = routeLayout1)
routeRow1 = mc.button( label='Select Target',command = 'sTarget()' ,p = routeLayout1)
routeRow33 = mc.textScrollList( 'targetgroup', numberOfRows=6, allowMultiSelection=True, a = [], w = 150, h = 22, p = routeLayout1,
showIndexedItem=1 )
mc.button( label='Transfer Materials',w = 150,command = 'tMaterials()' ,p =mainLayout)
mc.separator( height=30, w = 430, p = mainLayout )
mc.button( label='Close', command=('cmds.deleteUI(\"' + window + '\", window=True)') ,p =mainLayout)
mc.separator( height=20, w = 430, style='out', p = mainLayout )
mc.window('TransferTex', edit=True, widthHeight=(300, 300) )
mc.setParent( '..' )
mc.showWindow( window )
def sSource():
global shadingGrps
global sourceSel
global sameName
global sourceName
global shapesInSel
sameName = []
sourceName = []
transforms = mc.ls(type='transform')
deleteList = []
for tran in transforms:
if mc.nodeType(tran) == 'transform':
children = cmds.listRelatives(tran, c=True)
if children == None:
deleteList.append(tran)
if deleteList == []:
pass
else:
mc.delete(deleteList)
# get list of selection:
shapesInSel = mc.ls(dag=1,o=1,l=1,sl=1,g=True)
consrain = mc.ls(type='constraint')
# if len(consrain) > 0:
# mc.select(consrain)
# mc.parentConstraint(n= 'consrain', remove = True )
# else:
# pass
sourceSel = mc.ls(sl=True)
for sourceNames in shapesInSel:
sourceName.append(sourceNames)
oldnNames = sourceNames.split('|',2)
for oldName in oldnNames[2:]:
sameName.append(oldName.encode("utf-8"))
mc.textScrollList('sourcegroup',e = True, ai = True, append = sourceSel,removeAll = True)
def sTarget():
global shapesOutSel
global targetSel
global neName
neName = []
deleteList = []
pass
else:
# else:
# pass
# get samename of selection:
shapesOutSel = mc.ls(dag=1,o=1,l=1,sl=1,g=True)
targetSel = mc.ls(sl=True)
for targetNames in shapesOutSel:
neNames = targetNames.rsplit('|',5)
neName.append(neNames)
mc.textScrollList('targetgroup',e = True, ai = True, append = targetSel,removeAll = True)
def tMaterials():
global shadingGrps
global sourceSel
global shapesOutSel
global targetSel
global sameName
global neName
global sourceName
global shapesInSel
fullName = []
errorList = []
for comb in sameName:
fullName.append(str(targetSel[0] + '|' + comb))
for ii in shapesInSel:
snames = ii.rsplit('|',2)
shadingGrps = mc.listConnections(ii,type='shadingEngine')
if shadingGrps == None:
pass
else:
names = mc.listConnections(shadingGrps, type="mesh")
#print shadingGrps, "->", ", ".join(names)
CacheGroup = mc.ls(snames[-2], l=True)
if len(CacheGroup) < 2:
errorfinds = "# Warning: Can't find Geo" "%s"%(snames[-2])
errorfind = errorfinds + " in the target group"
errorList.append(errorfind)
someList = cmds.textScrollList('ErrorWarning', exists=True)
if someList == False:
Error = mc.textScrollList( 'ErrorWarning', numberOfRows=6, allowMultiSelection=True, a = [], w = 150, h = 62, p = mainLayout,
showIndexedItem=1 )
else:
pass
mc.textScrollList('ErrorWarning',e = True, ai = True, append = "%s"%(errorfind))
else:
mc.sets(CacheGroup, edit=True, forceElement="%s"%(shadingGrps[0]))
Geos = CacheGroup[0].split('|')
print shadingGrps[0], "assigned to object", Geos[-1]
for eacherror in errorList:
print eacherror
1 REPLY 1
Kahylan
Hi!
In this section:
else:
pass
else:
right at the end, you have two "else" statements following each other without an if statement inbetween. Thats your syntax error.
Hope this helps!
