how to choose a set set using python
2368457978
2368457978
Hello, everyone, python selection set can't be used (cmds.ls(sl=True, dag=True))? , my use is invalid,
def stepSize():
    set = cmds.ls(sl=True, dag=True)
    for each in set:
        STS = cmds.floatSliderGrp("stepSize", q=True, value=True)
        cmds.setAttr(each +".stepSize", STS)
def Set_att01():
    maxNumber = cmds.floatField("maxNumberOfGuideInfluences", q=True, v=True)
    print(maxNumber)
    for each in set:
        cmds.setAttr(each + ".maxNumberOfGuideInfluences", maxNumber)
def Set_att02():
    minimum = cmds.floatField("minimumNumberOfSteps", q=True, v=True)
    print(minimum)
    for each in set:
        cmds.setAttr(each + ".minimumNumberOfSteps", minimum)
cmds.rowLayout(nc=6)
cmds.text("GuideInfluences",w=110, h=20, bgc=(0.2, 0.5, 0.5))
cmds.floatField("maxNumberOfGuideInfluences", w=60, h=30,minValue=0, value=3, precision=0)
cmds.button("O K",w=60, bgc=(0.4, 0.2, 0.3), c="Set_att01()")
cmds.text("NumberOfSteps",w=110, h=20, bgc=(0.2, 0.5, 0.5))
cmds.floatField("minimumNumberOfSteps", w=60, h=30,minValue=0, value=10, precision=0)
cmds.button("O K",w=60, bgc=(0.4, 0.2, 0.3), c="Set_att02()")
cmds.setParent( '..' )
cmds.rowLayout(nc=2)
cmds.text("stepSize",w=110, h=20, bgc=(0.2, 0.5, 0.5))
cmds.floatSliderGrp("stepSize", field=True, w=350, min=0.001, max=1, value=0.001, step=0.001, fieldMinValue=0.001, fieldMaxValue=10.000,cc="stepSize()")
Kahylan
I'm not quite sure if I understand what your question is, because what you are doing is quite literally choosing the set itself.
I guess you want to know how to find the set members?
If so, this is it:
import maya.cmds as cmds
set = cmds.ls(sl = True)
for s in set:
    members = cmds.sets(s, q= True)
I hope it helps!
