Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
How do I get the filepath of a script that is loaded into the script editor?
3 REPLIES 3
marten.zanderBH2FZ
321 Views, 3 Replies
Hi fellow Maya Programmers!
I need some help figuring out a script's filepath from within maya using python. I have a certain script file located somewhere on my harddrive. Let's assume the file is called "C:/Users/Username/Desktop/test.py". In Maya's Script Editor I open the script file using "File" -> "Open Script..." Menu. A new Tab in my script editor appears, displaying the content of my test.py. What I am trying to do now, is run the test.py and print the folder location where that file (test.py) is stored.
Is there anyway to extract that path information?
Thanks in Advance!
Labels (2)
3 REPLIES 3
import maya.cmds as cmds
def getScriptEditorPaths():
    # Get the name of the scriptEditorPanel
    allPanels = cmds.getPanel( all=True )
    scriptPanel = [x for x in allPanels if 'scriptEditor' in x]
    if not scriptPanel:
        return []
    scriptPanel = scriptPanel[0]
    # Step through the layouts of the script editor until we find the tablayout
    f1 = cmds.layout(scriptPanel, q = True, childArray = True)
    f1, f2 = cmds.layout(formLayout1, q = True, childArray = True)
    p1 = cmds.layout(f2, q = True, childArray = True)
    sf, p2 = cmds.layout(p1, q = True, childArray = True)
    t1 = cmds.layout(p2, q = True, childArray = True)
    filePaths = []
    for eachChildLayout in cmds.tabLayout(t1, q = True, childArray = True):
        scrollFieldExec = cmds.layout(eachChildLayout, q = True, childArray = True)
        filePaths.append(cmds.cmdScrollFieldExecuter(scrollFieldExec, q = True, filename = True))
    return filePaths
This should work 🙂
Hey man, thank you for your reply. unfortunately I get an error saying that global name "formLayout1" is not defined.
Okay, I actually fixed it by myself already. I replaced "formLayout1" with f1[0] :). It's working, thanks a lot!
