Hey guys
So, I have two questions:
1) See the group in the yellow? How do I get it so it says "Left Elbow Joint_Offset Group" instead of "u_Left_Elbow_Joint__Offset_Group"?
2) I want to set the attributes of the group using the setAttr command, but how do I get the name of the group for the command i.e cmds.setAttr("Left Elbow Joint_Offset Group")?
1: I usually call the objects in the list by it's index that takes care of the "u_", like this
selectionindex = selection[0]
offsetGroup = base.group(em=True, n=str(selectionindex)+"_offset_group")
Or if you need it to happen to all of the objects in the list
for index in selection:
offsetGroup = base.group(em=True, n=str(index)+"_offset_group")
2: You can select it by using
cmds.select( '*_group' )
groupselection = cmds.ls(sl=True)
print groupselection[0]
for example 🙂
I hope this help.
