Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
get area of mesh face
2 REPLIES 2
bmagner888
293 Views, 2 Replies
How do I get the (worldspace units) of the area of any given mesh face?  Looking for a python solution.
most faces are not rectilinear and might contain any number of edges, so getting the attaced verts and doing some sort of spatial calculation is a nightmarish idea.
OpenMaya.MItMeshPolygon has a getArea() function but I can't figure out how to jump through all the hoops to actually use it, because  OpenMaya makes you recast everything through a hundred different class instances just to do simple things.  And the documentation isn't very helpful.
def get_face_area( 'polySurface1.f[0]'):
    area =?????????????????????
    return area
Thanks for any help.
2 REPLIES 2
jmreinhart
in reply to: bmagner888
import maya.api.OpenMaya as om2
def getMeshFaceArea(meshFace):
    # Get the mesh object as a dagPath
    selectionList = om2.MSelectionList()
    selectionList.add(meshFace)
    dagPath, component = selectionList.getComponent(0)
    # Create a polygon iterator
    meshIt = om2.MItMeshPolygon(dagPath,component)
    return meshIt.getArea(om.MSpace.kWorld)
Is there something specific about the documentation that you found difficult? I know I struggled when getting started with the API, so I'm happy to answer any questions.
bmagner888
in reply to: jmreinhart
this is perfect.  thank you.
-b
