Hi everyone, i would like to know if there is a full list and description of MEL commands, since this one have a limited number of commands https://help.autodesk.com/cloudhelp/2024/ENU/Maya-Tech-Docs/Commands/index.html
as example updateComponentSelectionMasks, dR_activeHandleX and i think all dR_XXXX commands are missing, right clicking in script editor those commands and selecting "Command Documentation" points to https://help.autodesk.com/view/MAYAUL/2024/ENU/
Solved by stephenkmann. Go to Solution.
updateComponentSelectionMask is a mel script. not a command
dR_activeHandleX is a runtime command not an internal command
use whatIs to find out what commands and scripts are..
ie:
whatIs updateComponentSelectionMasks;
// Result: Mel procedure found in: C:/Program Files/Autodesk/Maya2024/scripts/startup/statusLine.mel
whatIs dR_activeHandleX;
// Result: Run Time Command
whatIs saveAllShelves;
// Result: Command
For runtime commands you can often find them thru the hotKey editor.
set the search by: to 'runtime command' and put the name of the command into the input field,
hth
-=s
ok thanks! didn't thought there was a difference between mel and runtime commands, so the list provided in the link i posted is complete?
there is no complete documentation that i know of. the official one has several missing cmds
You should rely on documented Maya commands as much as possible.
Large portions of Maya are implemented in Mel/Python and are not document these as they could change in a future release. However, in many cases you can look at the undocumented script to find out what commands it is using internally and this can be extremely useful as a guide when developing you own scripts.
