Disable Dialog on MSceneMessage.kBeforeSaveCheck Callback
AronDurkin
AronDurkin
hello!
Does anyone know how to disable this dialog when using om2.MSceneMessage.addCheckCallback(om2.MSceneMessage.kBeforeSaveCheck, before_save_check). OR does any one know another way i can run code on save, check stuff and stop it saving should I need to? (if the answer is, override SaveScene and SaveSceneAs in defaultRunTimeCommands.mel, then sure, but I need this on a shared script path, and thus, can i set maya version specific scripts on a shared path? guess I'd need to setup that up on startup getting the version?)
I know how to change the text in this dialog, but would love to disable it and show my own / do whatever i want.
thanks
FirespriteNate
In the docs it says kBeforeSaveCheck is explicitly to allow users to confirm something (i.e. "allows user to cancel action" - which presumably necessitates a dialog). If you want the same behaviour without the dialog, isn't kBeforeSave a better choice for that?
AronDurkin
Correct me if I’m wrong but in my testing kBeforeSave doesn't allow you to abort the save. You can throw an error in the function given to that callback but ultimately the file will still save. Ideally I would not let the user save under certain conditions.
