Python Set Anim Layer RotationAccumulation by layer
elfenliedtopfan5
elfenliedtopfan5
Good morning all,
i have been trying for a couple of days now to set the rotationaccumulation by layer in python but cant seem to get it to work
what i have tyried so far
def create_anim_layer():
    # Create an animation layer
    anim_layer = cmds.animLayer("Idle_AnimLayer", override=True)
    # Set the rotation accumulation to "by layer" using MEL
    mel_command = 'editAnimLayer -e -rotationAccumulation "byLayer" "{}";'.format(anim_layer)
    mel.eval(mel_command)
    # Adjust the number of frames to the maximum frame count
    max_time = cmds.playbackOptions(q=True, max=True)
    cmds.animLayer(anim_layer, edit=True, override=True, at=max_time)
    # Set the rotation accumulation to "by layer" using cmds.setAttr
    cmds.setAttr('{}.rotationAccumulation'.format(anim_layer), 'byLayer')
    # Set the rotation accumulation to "by layer" using the SEToolsPlugin module
    mel_command = 'animLayer -edit -rotationAccumulation "byLayer" "{}";'.format(anim_layer)
however i cant seem to get the correct name it keeps coming up with errors like
# Error: AttributeError: file <maya console> line 44: module 'maya.cmds' has no attribute 'editAnimLayer'
this is the current one i was working on but still no luck
all i really need to do is change the anim layer to by layer does anyone here know how that could be acchived in python ?
thank you in advance
elfenliedtopfan5
FirespriteNate
I don't have 2023 installed here, only 2022, but when I execute
whatIs editAnimLayer;
in MEL, it returns "Unknown", which means editAnimLayer is NOT a regular cmds command, so will not work in python using cmds. There are only three other alternatives I can think of, it's a plug-in command, so will become available to cmds if the plug-in is enabled, it's a runtime command (unlikely as it doesn't start with an uppercase letter), or, most likely it's a MEL script that hasn't been sourced yet.
If the MEL code above DOES return a valid mel file source path when you run it, then you simply have to ensure the mel script it specifies is sourced before you run your code.
However, I just did a search on the entire Maya2022 install folder and "editAnimLayer" produced zero hits.. are you sure it's actually a valid command/function/script?
elfenliedtopfan5
import maya.cmds as cmds
import maya.mel as mel
import maya.OpenMaya as om
import SEToolsPlugin  # Import the SEToolsPlugin module
def import_se_anim_file(file_path):
    # Call the Python function directly from the imported module
    SEToolsPlugin.__load_seanim__(file_path, scene_time=False, blend_anim=False)
    # Select all joints
    cmds.select("Joints", hi=True)
    # Get the time range
    min_time = cmds.playbackOptions(q=True, min=True)
    # Copy the keyframes with the time range specified
    cmds.cutKey(time=(min_time, max_time), clear=True)
    print("cutkey")
    # Paste the keyframes back to the original joints
    cmds.pasteKey(time=(min_time, max_time), option="replace")
    print("pasteworked", min_time, max_time)
def import_se_anim_file_and_create_anim_layer(*args):
    # Specify the path to your SE Anim file
    se_anim_file_path = r"path removed but path to anim file need to be loaded"
    # Call the import_se_anim_file function
    import_se_anim_file(se_anim_file_path)
    # Call the create_anim_layer function
    create_anim_layer()
    # Call the copy_and_paste_to_anim_layer function
    copy_and_paste_to_anim_layer()
    # Set the rotation accumulation to "by layer" using cmds.editAnimLayer
    cmds.editAnimLayer(anim_layer, edit=True, rotationAccumulation="byLayer")
def copy_and_paste_to_anim_layer():
    # Select all joints
    cmds.copyKey(time=(min_time, max_time), clear=True)
    # Paste the keyframes into the animation layer
    cmds.pasteKey(time=(min_time, max_time), option="replace", targetClip="Idle_AnimLayer")
# Call the import_se_anim_file_and_create_anim_layer function
import_se_anim_file_and_create_anim_layer()
this is the full code its higly possible its not a mel command new to python and have been looking up tutorials and using addinal resorces from other places to get a understanding of this however i manged to get it to make the animlayer i just cant get it to change the rotation accumcation to by layer been trying to do it for couple of days now these ones are the only ones i saved
FirespriteNate
I still have no idea where you are getting editAnimLayer from, but if you just want to set the layer's "Rotation Accumulation" mode to "By Layer", don't you just need to do this:
cmds.setAttr(anim_layer+'.rotationAccumulationMode', 1)
 which is basically what the ScriptEditor spits out (but in MEL) when you do it manually?
elfenliedtopfan5
yes it does and yes that does work i been going by lable name so rotationaccumulation - bylayer when it is execting ,1 or 0 messed that up badly thank you for your reply been very helpful marked as answer
