Just tried to port one of my scripts to Maya 2022 and noticed that templates don't work. Maya imports my .py file but seems to ignore its content at all. Python 2 mode works fine
Update:
It's a bug.
Here's a little code. Works perfectly in Python 2 mode.
In Python 3 I can register it, AELoader.loadedTemplates() confirms that template is loaded, but when I create node and open attribute editor it throws exception:
# Error: line 2: ValueError: file C:\Program Files\Autodesk\Maya2022\Python37\lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py line 142: level must be >= 0 #
import maya.api.OpenMaya as om2
import pymel.core as pm
maya_useNewAPI = True
class Template(pm.ui.AETemplate):
_nodeType = "testNode"
def __init__(self, *args):
self.beginScrollLayout()
self.addExtraControls()
self.endScrollLayout()
class Node(om2.MPxNode):
NAME = "testNode"
ID = om2.MTypeId(0x00047374)
@classmethod
def initialize(cls):
pass
def initializePlugin(m_object):
plugin = om2.MFnPlugin(m_object)
plugin.registerNode(Node.NAME, Node.ID, Node, Node.initialize)
def uninitializePlugin(m_object):
plugin.deregisterNode(Node.ID)
Found a solution:
open Maya2022\Python37\Lib\site-packages\pymel\core\uitypes.py
find AELoader.load() method and and remove -1 from __import__() arguments. It fixes a problem for cases when template is placed in another module and being imported.
Otherwise throws exception: AttributeError: module 'builtins' has no attribute 'ClassName'
