Announcements
Did I missed something on my Maya install that every scripts wont run?
KokiWatafak
KokiWatafak
All of these python scripts to generate stairs just outright not working at all. On script editor, when I click execute it didn't do anything as in nothing happened, not even error (except for the 2nd code which spits out // Error: Line 2.19: Invalid use of Maya object "object". error when I move it from Python tab to MEL. Btw I found the 2nd code from this post). Saving it as a .py file and putting it on the scripts folder on Documents\Maya didn't do anything. Drag and dropping the .py file directly to Maya didn't do anything. And I'm pretty sure there's supposed to be Scripts menu that is usually sitting between Arnold and Substance menu which didn't exists for me (Substance menu also didn't exists for me but I'm not looking for this for now. It's usually sits near Cache menu so in order it's Cache - Substance - Scripts - Arnold, but those two just do not exists at all)
Code 1:
    OptionsWindow is a class definition of the basic window class.
    The class is adding a set of controls to create a template
    that resembles Maya's built-in tool option windows.
import maya.cmds as mc
class OptionsWindow(object):
    """Base Window Class"""
    # This method was indented incorrectly and missing @classmethod decorator
    @classmethod
    def showUI(cls):
        win = cls()
        win.create()
        return win
    def __init__(self):
        self.window = "optionsWindow"
        self.title = "OptionsWindow"
        self.size = (546, 350)
        self.button1 = "Action"
        self.button2 = "Apply"
        self.button3 = "Close"
    def create(self):
        if mc.window(self.window, exists=True):
            mc.deleteUI(self.window, window=True)
        self.window = mc.window(self.window, title=self.title, widthHeight=self.size, menuBar=True)
        self.mainForm = mc.formLayout(nd=100)
        self.commandMenu()
        self.commonButtons()
        self.optionsBorder = mc.tabLayout(scrollable=True, height=1)
        mc.formLayout(self.mainForm, e=True,
                      attachForm=[
                          (self.optionsBorder, "top", 0),
                          (self.optionsBorder, "left", 2),
                          (self.optionsBorder, "right", 2)
                      attachControl=[
                          (self.optionsBorder, "bottom", 5, self.applyBtn)
        self.optionsForm = mc.formLayout(nd=100)
        mc.tabLayout(self.optionsBorder, edit=True, tabLabel=(self.optionsForm, "Test"))
        self.displayOptions()
        mc.showWindow()
    def commandMenu(self):
        self.editMenu = mc.menu(label="Edit")
        self.editMenuSave = mc.menuItem(label="Save Settings", command=self.editMenuSaveCmd)
        self.editMenuReset = mc.menuItem(label="Reset Settings", command=self.editMenuResetCmd)
        self.helpMenu = mc.menu(label="Help")
        self.helpMenuItem = mc.menuItem(label="Help on %s" % self.title, command=self.helpMenuCmd)
    def helpMenuCmd(self, *args):
        mc.launch(web="http://maya-python.com")
    def editMenuSaveCmd(self, *args):
        pass
    def editMenuResetCmd(self, *args):
        pass
    def actionCmd(self, *args):
        print("ACTION")
    def applyBtnCmd(self, *args):
        print("APPLY")
    def closeBtnCmd(self, *args):
    def commonButtons(self):
        self.commonBtnSize = (self.size[0] - 18) / 3, 26
        self.actionBtn = mc.text(label='')
        self.applyBtn = mc.text(label='')
        self.closeBtn = mc.button(label=self.button3, height=self.commonBtnSize[1], command=self.closeBtnCmd)
        mc.formLayout(self.mainForm, e=True, attachForm=[
            (self.actionBtn, "left", 5),
            (self.actionBtn, "bottom", 5),
            (self.applyBtn, "bottom", 5),
            (self.closeBtn, "bottom", 5),
            (self.closeBtn, "right", 5)
        ], attachPosition=[
            (self.actionBtn, "right", 1, 33),
            (self.closeBtn, "left", 0, 67)
        ], attachControl=[
            (self.applyBtn, "left", 4, self.actionBtn),
            (self.applyBtn, "right", 4, self.closeBtn)
        ], attachNone=[
            (self.actionBtn, "top"),
            (self.applyBtn, "top"),
            (self.closeBtn, "top")
    def displayOptions(self):
        pass
class MyOptionsWindow(OptionsWindow):
    """Custom Window Class, subclass of the OptionWindow base class"""
    def __init__(self):
        self.radius = mc.floatFieldGrp(self.grp, query=True, value1=True)  # get value'
        mc.polySphere(r=self.radius)
        # Here insert custom controls
        # self.grp = mc.floatFieldGrp(numberOfFields=1, label="Radius", value1=5.0)
        mc.columnLayout()
        mc.text(label='StairSize')
        mc.text(label='Step Number')
        mc.intField("Steps", minValue=0, maxValue=50, value=10)
        mc.text(label='Angle PerStep')
        mc.intField("Angle", minValue=0, maxValue=360, value=15)
        mc.text(label='Step Dimension')
        self.stepXYZ = mc.floatFieldGrp(numberOfFields=3, label="input vector", value1=5.0, value2=3.0, value3=0.5)
        mc.button(label="Regular", command=self.Normal, w=130)
    def Normal(self, *args):
        self.Nstep = mc.intField("Steps", q=True, value=True)
        step = []
        width = mc.floatFieldGrp(self.stepXYZ, query=True, value1=True)  # red X
        depth = mc.floatFieldGrp(self.stepXYZ, query=True, value2=True)  # blue Z
        height = mc.floatFieldGrp(self.stepXYZ, query=True, value3=True)  # green Y
        for number in range(self.Nstep):
            step.append(mc.polyCube(w=width, d=depth, h=height, n='Smallstep')[0])
            mc.move(0, number * height, (depth / 2) * number * -1, r=True)
        self.twisteps = mc.group(step, name="AllSteps")
        self.EntireStaircase = mc.group(em=True, name='EntireStaircase')
        mc.group('AllSteps', parent='EntireStaircase')
        self.valueX = mc.floatFieldGrp(self.grp2, query=True, value1=True)
        self.valueY = mc.floatFieldGrp(self.grp2, query=True, value2=True)
        self.valueZ = mc.floatFieldGrp(self.grp2, query=True, value3=True)
        finalCube = mc.polyCube(w=self.valueX, h=self.valueY, d=self.valueZ, n="myCube")
def EncapsulatedStairsGenerator():
    win = MyOptionsWindow()
    win.create()
Code 2:
from maya import cmds
class Stair(object):
    import stairCreator as sc
    reload(sc)
    stair = sc.Stair()
    stair.createStair()
    stair.changeStair(steps=05, height=1)
    # init sets up default vales
    def __init__(self):
        self.transform = None
        self.extrude = None
        self.constructor = None
    def createStair(self, steps=20, height=1, length=24, width=10):
        self.transform, self.constructor = cmds.polyPlane(subdivisionsHeight=steps, subdivisionsWidth=1, width=width, height=length)
        self.frontFaces = range(steps)
        for face in self.frontFaces:
            self.extrude = cmds.polyExtrudeFacet('%s.f[%s:%s]' % (self.transform, face, steps-1), localTranslateZ=height)[0]
    # changeing shape after creation----------------------------------
    def changeStair(self, steps=20, height=1, length=24, width=10):
        cmds.polyPlane(self.constructor, edit=True, subdivisionsHeight=steps, width=width, height=length, scaleY=height)
Did I do something wrong here? What am I missing? Or if there's nothing really wrong with the first code, where do I go to launch the stair generator window? Maya version is 2019
mcw0
See your other post
