looking for a custom transform node API (copy of basic transform)
tdufourL9X6T
Observer Observer
tdufourL9X6T
Observer
Observer
Here is my problem, I am looking for the code to create a custom transform node, the most basic one.
The goal is to give it a custom AETemplate so that it is not applied to all transform nodes.
I have searched everywhere, even in the API, to create this custom transform node. I have used AI to help me generate the code, but nothing works, it still doesn't work.
If anyone competent can provide me with access to the transform code file or write the code for me in the API (I specify that it is the basic transform with translation, rotation, scale, and everything else), it would be greatly appreciated.
Thank you for your help, I've tried everything. Moreover, the API documentation is particularly difficult to understand...
Thank you so much for your valuable help!
PS : Merry Christmasx
brentmc
There is a custom transform example included in the Maya Developer Kit:
https://help.autodesk.com/view/MAYADEV/2025/ENU/?guid=Maya_DEVHELP_Writing_a_Custom_Transform_Node_h...
Brent McPherson
Principle Software Developer
