Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Delete unknown nodes in Python
3 REPLIES 3
13843 Views, 3 Replies
Is there a way to delete unknown noeds from within Maya using Pyhton
#Something like...
for item in unknownNodes:
  if node.exists:
    delete node
print unknownNodes # []
#Something like...
  if node.exists:
    delete node
3 REPLIES 3
haggi_master
haggi_master
import maya.cmds as cmds
cmds.delete(cmds.ls(type="unknown"))
rajasekaransurjen
unknownNodes=cmds.ls(type = "unknown")
    if cmds.objExists(item):
        print item
        cmds.delete(item)
        print item
        cmds.delete(item)
ijdallas
Thanks, rajasekaransurjen, your code handles ALMOST all the unknown nodes.
It looks like there's another type, "unknownDag" that Maya also uses (eg for Mental Ray nodes if the plugin isn't loaded). I updated your code to include that type, and to unlock nodes before deleting them since Maya will refuse to delete any locked nodes:
unknownNodes+=cmds.ls(type = "unknownDag")
        print item
        cmds.lockNode(item, lock=False)         cmds.delete(item)
A recent Autodesk post also discusses a few more ways to remove unknown nodes, for example by using the Optimize Scene Size command: https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable-to...
        print item
